SMSL IQ USB OTG ANDROID DAC Headphone Amplifier ES9018Q2C XMOS U208 Black
SMSL IQ is a nomadic Android DAC with two Es9028 Q2c chips and a high quality headphone output section. Its USB Xmos U208 input makes it a first choice for transforming its smartphone into a true audiophile DAC with high fidelity headphone amplification.
Reference : 12536
149,00 €tax incl.
124,17 € tax excl.
SMSL iQ DSD512
DAC USB OTG, headphone amplifier
A complete nomadic Hifi DAC
USB XMOS U208
The SMSL iQ is the second generation of mobile SMSL DAC SMSL with USB XMOS208 input. It thus offers a theoretical resolution up to DSD512 or 32bit 384Khz bringing the highest definition on a nomadic set.
Dual precision Clock and dual DAC
Featuring two ES9018Q2C DAC chipset with truly symmetrical high performance headphone amplification, the SMSL iQ benefits from high decoding accuracy supported by two Hy brand clocks with multiple separate frequencies (49.152Mhz and 45.1584mhz) with low noise phase. (jitter). The SMSL iQ thus proposes measurements and distortion figures comparable to sedentary hifi DACs.
One 2.5mm balanced headphone jack output
The SMSL iQ offers two headphone outputs, a classic 3.5mm jack and a 2.5mm balanced jack output for high quality Hifi headphones. Thanks to its symmetrical topology since the conversion the SMSL iQ allows a listening comparable to its classical Hifi channel.
high quality components
The SMSL iQ offers the best in a nomadic DAC with ultra-low noise voltage regulators, separate low drift clocks, a 15W413 LAP volume controller renowned for its balance between stereo channels. The figures show this high level construction with a background noise of -125dB and a total harmonic distortion of 0.00033%.
Technical Specification
THD+N0.00033%
Dynamic ratioDAC : 125dB
SNR118dB
Transmission USBAsynchrone Xmos U208
sampling rate / BitrateUSB : 32bit 768kHz & DSD512 (22.5792MHz)
Power jack 3.5mm55mW 32Ohm / 33mW 64ohm / 21mW 150ohm / 12mW 300ohm
power  jack 2.5 balanced91mW 32 Ohm / 78mW 64 Ohm / 53mW 150 Ohm / 32mW 300 Ohm
Battery charge voltage DC5V DC
entrées / Sorties
USB input1x 16bit/24bit/32bit/1bit et DSD64/DSD128/DSD256/DSD512
2x
Headphone Jack 3.5mm1x
Dimensions95 x 56 x 9mm
Weight200g
MaterialAlluminium CNC
Colorblack
Package1x câble USB-B vers USB-A mâle 1.5m, 1x câble IEC 1.5m, 1x télécommande (nécessite 2 piles AAA non fournies), manuel en anglais
OutputJack 3.5mm
OutputJack 2.5mm
Download
Driver SMSL 2018 V4.47
Windows Driver (newest version)
Download (2.79M)
2 reviews
Excellentissime
Le son est de très haute qualité. Testé sur smartphone Android avec poweramp et neutron.
Vraiment impressionnant.
This review has been posted for SMSL IQ USB OTG ANDROID DAC Headphone Amplifier ES9018Q2C XMOS U208 Black
Sans surprise, un excellent DAC portable
Après 18 mois de pérégrinations diverses et variées avec le sympathique mais fragile Chord Mojo (échange sous garantie, 2e chauffant assez pour se mettre en rideau toutes les 30 mn,...), je lui ai trouvé chez SMSL un très honorable remplaçant : cet iQ double-puce Sabre sait se faire oublier et c'est tout ce que je lui demande. Plus dynamique qu'un iFi Nano iDSD et moins flatteur que le MOJO, il évite les travers (aigus un poil envahissants) propres à certains DAC Sabre plus anciens. Tour à tour, connecté à un MacBook, à un laptop tournant sous Ubuntu ou à un Samsung Note3 me permettant de me connecter à MyCanal ou à Tidal, il fait le job sans jamais faillir et il le fait bien, à mes oreilles tout au moins, que ce soit en voiture ou, le soir, à l'hotel. Du SMSL, en somme ! Merci Audiophonics.
SMSL IQ is a nomadic Android DAC with two Es9028 Q2c chips and a high quality headphone output section. Its USB Xmos U208 input makes it a first...
