TANCHJIM LUNA Portable USB DAC
Tanchjim's Luna is a compact and efficient portable DAC, its elegant CNC aluminum finish housing a pair of CS43198 DAC chips coupled with quality circuits to convert signals up to PCM 32bit 768kHz and DSD256 while delivering rich, powerful audio quality with impressive dynamic range.
Reference : 20406
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 16-04-2025.
Tanchjim Luna Portable USB DAC 2x CS43198 32bit 768kHz DSD256
Tanchjim Luna : Front view
Tanchjim's Luna is a compact and efficient portable DAC. Its elegant CNC machined aluminum finish housing a pair of CS43198 DAC chips coupled with quality circuits to convert signals up to PCM 32bit 768kHz and DSD256 while delivering rich, powerful audio quality with impressive dynamic range.
Tanchjim Luna : summary of features
Tanchjim Luna : CNC aluminum housing
The Luna features an elegantly curved CNC-machined aluminum case. The brand logo is adorned with a reflective surface, completing a design that is both refined and minimalist.
Tanchjim Luna : Reflective Tanchjim logo
Tanchjim Luna : Dual DAC chips
Tanchjim Luna : Dual DAC CS43198
The Luna's digital-analog conversion stage is based on a pair of Cirrus Logic CS43198 DAC chips, enabling it to support an audio stream up to PCM 32bit 768kHz and DSD256, while offering precise, noise-free reproduction with an incredibly low level of harmonic distortion.
Tanchjim Luna : Quality circuit
The Luna has also benefited from special attention in its circuit design. Each stage of signal processing is supplied with independent voltage, thanks to a low-noise power supply supported by synchronous rectifier technology, ensuring rich, powerful sound with impressive dynamics.
Tanchjim Luna : Excellent performance
The Luna boasts excellent performance, with a dynamic range of 132.5dB and a signal-to-noise ratio (SNR) of 132dB. Furthermore, it also boasts a harmonic distortion rate of just 0.00014%, allowing you to enjoy a listening experience that's both rich in detail and devoid of imperfections.
Tanchjim Luna : SNR and dynamic range measurement
Tanchjim Luna : Tanchjim application
Thanks to the Tanchjim application available here, you can modify many of the Luna's parameters, including gain level, channel balance and the ability to switch from Class AB operation for greater stability and linearity, to Class H operation for greater efficiency.
Tanchjim Luna : Class management menu
Tanchjim Luna : Non-linear volume control
To make volume control as pleasant as possible, the Luna features a non-linear progression of attenuation, while decoupling the volume control from the output stage for transparent attenuation to the ear.
Tanchjim Luna : Volume attenuation curve
Tanchjim Luna : USB cable
Tanchjim Luna : Silver-plated USB cable
The Luna is supplied with a high-quality USB 2.0 standard cable, with silver-plated single-crystal copper conductors to guarantee high-performance data transmission without electromagnetic interference.
Tanchjim Luna : Maximum compatibility
The Luna has a single-ended 3.5mm jack output and a balanced 4.4mm jack output. This makes it compatible with most headphones for everyday use.
Tanchjim Luna : Dual headphone output
Tanchjim Luna review by AudioScienceReview (Amir)
" I am happy to recommend the TANCHJIM Luna DAC. We have arrived at a new era in portable products, achieving near top-end desktop class performance. "
Logo Audio Science Review
Product typePortable DAC
Input1x USB-C
Output1x Single-ended Jack 3.5mm headphone output
1x Balanced Jack 4.4mm headphone output
DAC Chip2x CS43198
Output power175mW @ 16Ω
285mW @ 32Ω
54mW @ 300Ω
Output voltageBalanced output : 4Vrms (High) / 2Vrms (Low)
Single-ended output : 2Vrms (High) / 1Vrms (Low)
Frequency response8Hz - 80kHz
Total harmonic distortion more noise (THD+N)0.00014%
Background noiseBalanced : 1.3µV
Single-ended : 1µV
Dynamic rangeBalanced : 132.5dB
Single-ended : 127dB
Supported samples ratesPCM up to 32bit 768kHz
DSD up to DSD256
ColorSilver
Package1x Tanchjim Luna
1x USB-C cable
1x USB-A to USB-C adapter
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43198
Max sampling rate768kHz
Max sampling rateDSD256
ColorSilver
TANCHJIM LUNA Portable USB DAC 2x CS43198 32bit 768kHz DSD256
Tanchjim's Luna is a compact and efficient portable DAC, its elegant CNC aluminum finish housing a pair of CS43198 DAC chips coupled with...
