TANCHJIM SPACE LITE Portable USB DAC CS43131 32bit 384kHz DSD256
The Tanchjim Space Lite is an ultra-compact and efficient portable DAC. It adopts a premium finish with a CNC machined one-piece aluminum alloy frame. The aluminum chassis provides resistance to potential external interference.
Reference : 17667
49,90 €tax incl.
41,58 € tax excl.
TANCHJIM SPACE LITE
TANCHJIM SPACE LITE DAC USB Portable CS43131 32bit 384kHz DSD256 Argent
Tanchjim Space Lite
Tanchjim Space
DAC chip
1* CS43131
2* CS43131
Output
1* Single-ended Jack 3.5mm
1* Balanced Jack 4.4mm
Volume control
No
Yes
Dynamic range
126dB
132dB
CS43131 DAC
The Space Lite's digital-to-analog conversion stage uses a Cirrus Logic CS43131 DAC chip. Powerful, it supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256, while offering precise and neutral reproduction. The dynamic range of this DAC reaches 126dB.
One single-ended high-power stereo output
The Tanchjim Space Lite's single-ended Jack 3.5mm headphone output port can provide an output level of up to 2Vrms and can drive most IEMs with its power up to 105mW.
A circuit with low consumption and high efficiency
The Space Lite is equipped with a low-power circuit that prevents overheating and does not discharge the device quickly, delivering the audio signal without reducing the battery life of your smartphone for example.
USB DAC function
Although designed for mobile use, the Tanchjim Space Lite can also be used as a USB DAC for computers. Simply plug it into a USB port on your machine to enjoy better sound quality.
Technical Characteristics
SpEcifications
Product typePortable DAC
Input1* USB-C
Output1* Single-ended Jack 3.5mm headphone output
DAC Chip CS43131
Output power105mW @ 16Ω
Ouput levelUp to 2Vrms
Frequency response20Hz - 80kHz
THD+N0.0003%
Background noise1µV
Dynamic range126dB (AES17 20Khz, A-weighted)
Supported sample ratesPCM up to 32bit 384kHz
DSD up to DSD256
Dimensions375*137*100mm
Weight10.9g
ColorSilver
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate384kHz
ColorSilver
Pour le prix foncez
Testé, niveau son, identique au Space.
La différence se trouve sur les boutons du Space.
Bien meilleur que les DAC de mon S23 et de ma TAB S9+ et celui de mon PC. Coté design, il est tout pititoumignon et robuste.
Il est pas overkill mais franchement pour une écoute nomade, il n'y a pas mieux et compact.
Par contre comme son grand frère des petit bugs sonores lorsque plug - deplug de temps à autre.
This review has been posted for TANCHJIM SPACE LITE Portable USB DAC CS43131 32bit 384kHz DSD256
The Tanchjim Space Lite is an ultra-compact and efficient portable DAC. It adopts a premium finish with a CNC machined one-piece aluminum alloy...
