The Tanchjim Stargate 2 is a portable DAC and headphone amplifier with USB-C male and Jack 3.5mm female connectors. It's ideal for enjoying high-quality listening on a smartphone without a 3.5mm headphone output.
What's more, it integrates seamlessly with the Tanchjim mobile application. It provides access to a DSP with eight-band parametric equalizer for easy adaptation of sound reproduction.
Thanks to its integrated DAC chip, it supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256. It offers excellent sonic performance with high SNR and DNR, as well as very low distortion, for clear, precise sound.
The Tanchjim Stargate II features a high-performance Cirrus Logic CS43131 DAC and headphone amplifier chip. It supports high-resolution audio streams up to PCM 32bit 384kHz and DSD256, while ensuring high SNR and DNR and very low distortion for rich, clear and precise sound reproduction.
The Tanchjim Stargate II makes it easy to take calls with your headphones or earphones. It features a high-resolution 24bit 48kHz ADC chip, with a signal-to-noise ratio of 84dB, for crystal-clear calls.
Using metal-bodied connectors and a braided sheath, the Tanchjim Stargate II is tough but extremely lightweight, weighing just 4.3g.
The Tanchjim Stargate II integrates with the Tanchjim mobile app (Android and iOS). It provides access to the DSP with an eight-band parametric equalizer for fine-tuning sound reproduction.
Download Tanchjim Mobile AppThanks to high-quality design and components, the Stargate II offers a dynamic range (DNR) of 127.5dB and a signal-to-noise ratio (SNR) of 127.4dB.
The Tanchjim Stargate II ensures very low harmonic distortion of 0.0002%, and its SINAD reaches an impressive 113dB.
Product type | Portable DAC and headphone amplifier USB-C to Jack 3.5mm adapter |
Connectors | 1x Male USB-C 1x female Jack 3.5mm |
Supported sampling rates | PCM up to 32bit 384kHz Native DSD up to DSD256 |
THD | 0.00023% |
Dynamic range | 127.4dB |
SNR | 127.4dB |
SINAD | 113dB |
Output level | 2Vrms |
Crosstalk | -75dB |
Output power | 82mW @ 16Ω, THD+N <1% 75mW @ 32Ω, THD+N <1% |
Color | Silver |
Package | 1x Tanchjim Stargate II |
