XDUOO LINK USB-C DAC Adapter Hi-Res ES9118 32bit 384kHz DSD256
Recent smartphones are increasingly abandoning the 3.5mm Jack audio connectors, now replaced by USB-C. Phones no longer carry a DAC and it is necessary to use an adapter with a conversion chip to be able to enjoy its music. This is what the xDuoo Link, a USB-C DAC adapter, offers, based on a high-quality conversion chip for rich and accurate playback.
4.5 / 5
Reference : 14157
39,90 €tax incl.
33,25 € tax excl.
This product has been replaced by the new version, the XDUOO LINK V2 Portable USB DAC CS43131.
XDUOO LINK
xDuoo Link Adaptateur DAC USB-C Hi-Res ES9118 32bit 384kHz DSD256
Hi-Res
The xDuoo Link complies with the Hi-Res Audio standard. This certification issued by the Japan Audio Society guarantees a high quality of sound reproduction thanks to the support of high resolution audio files and the reproduction of a wide range of frequencies.
High Performance DAC
The Link is equipped with a DAC ESS ES9118EC chip. Where a standard smartphone conversion chip can only decode up to 16bit 48kHz, the Link supports files up to 32bit 384kHz and DSD256 for more accurate, rich and accurate playback. In addition, it offers very good audio performance such as a Signal to Noise ratio measured at 115dB.
Comparison of xDuoo Link digital output and classic 3.5mm jack output
Integrated Amplifier & Optimized Power Consumption
The adapter also includes an amplifier, capable of adapting to the impedances of the various listening devices (headphones, headphones, in-ear monitors, etc.). Developing a power of 32mW under 32Ω, the Link is however optimized to offer a low power consumption.
Compact & Resistant
The Link has been designed to accompany you in all your travels. Its design is therefore compact, practical and lightweight, with only 15g on the meter, but resistant. Thus, the DAC housing is made of CNC machined aluminium, which is particularly robust.
Battery-free design
The xDuoo Link does not include a battery but consumes a very small amount of power from the device to which it is connected. This design avoids any problem related to a forgotten charge.
PC USB DAC Feature
If it was first designed to work with your smartphone, the xDuoo Link is also compatible with your computer running Mac OS, Windows 7/8/10 or Linux. Thus, it is possible to enjoy the decoding quality of the xDuoo Link on your smartphone as well as on your computer.
Product typeDAC USB-C
DAC ChipES9118EC
InputUSB-C
OutputJack 3.5mm
Cable length90mm
Supported sampling ratePCM up to 32bit 384kHz
DSD up to DSD256
Output power32mW @ 32Ω
Frequency response20Hz - 20kHz (+/-0.5dB)
THD+N0.0018% @ 1kHz
SNR115dB
Crosstalk>= 77dB
Dimensions60 x 13 x 7.2mm
Weight15g
ColorCable: Orange
Connector and housing : Black
OutputJack 3.5mm
ColorOrange
2 reviews
Bien mais attention aux boutons
Un niveau de volume équivalent au dongle apple avec contrôle du volume, mais attention : les boutons ne contrôlent pas le dac/amp interne, uniquement l'app.
Ce Link est donc incompatible avec le XDUOO X10TII, c'est bon à savoir...
Sinon pas tout à fait neutre, un poil de basses en plus et des aigus un peu secs. Dans l'absolu c'est une bonne chose. Cela dépend donc du combo Link+casque que vous allez mettre en place.
Xduoo est vraiment une très bonne marque.
This review has been posted for XDUOO LINK USB-C DAC Adapter Hi-Res ES9118 32bit 384kHz DSD256
topmoumoutte
tres bon dac couplé au xiaomi Mi9T, utilisé avec un porta pro, il a une bonne reserve de puissance, testé avec un k712 pro et k701, c'est un peu juste quand meme, disons que c'est ca devient quand meme ecoutable, pour la qualité de son, c'est ultra detaillé, y'a une foule de micro details, signature typique de l'ESS sabre, ce qui fais un bien fou au koss portapro un peu leger sur l'aigu.Dac reconnu de suite avec neutron music player, idem sur pc, reconnu de suite sans driver.
Recent smartphones are increasingly abandoning the 3.5mm Jack audio connectors, now replaced by USB-C. Phones no longer carry a DAC and it is...
