XDUOO LINK V2 Portable USB DAC CS43131 32bit 384kHz DSD256 Gray
10%
The xDuoo Link V2 portable DAC follows the design and concept of its big brother, the Link, in a version with improved performance.
Reduced price!
Reference : 15839
Limited special offer
54,90 €tax incl.
-10%
49,41 €tax incl.
41,18 € tax excl.
xDuoo Link V2
xDuoo Link V2 DAC USB Portable CS43131 32bit 384kHz DSD256
Link V2
Link
DAC Chip
CS43131
ES9118
Output power
80mW @ 32 Ohm
32mW @ 32 Ohm
Supported sampling rates
PCM 32bit 384kHz, DSD256
Frequency response
20Hz - 20kHz
20Hz - 20kHz
SNR
125dB
115dB
THD+N
0.0010%
0.0018%
Automatic power adjustment
Yes
No
Input
USB-C
USB-C
Output
Jack 3.5mm
Jack 3.5mm
Dimensions
60 x 13 x 7.2mm
60 x 13 x 7.2mm
Weight
13g
15g
xxx
CS43131 DAC
The Link V2's digital to analog conversion stage uses a Cirrus Logic CS43131 DAC chip. This powerful chip supports high resolution audio streams up to PCM 32bit 384kHz and DSD256, while offering a precise and neutral reproduction. It also allows the Link V2 to benefit from the Hi-Res Audio certification.
Low Consumption & Adaptive Power
Le Link V2 ensures low power consumption, so you can use it for long periods of time in combination with your smartphone. In addition, it has an intelligent system that automatically adjusts the output power according to the impedance of the connected listening device.
xxx
xxx
Energy management
The Link V2 has no built-in battery and is directly powered by the smartphone to which it is connected, using only a very small amount of energy. It does not need to be recharged.
USB DAC function
Although designed for mobile use, the Link V2 can also be used as a USB DAC for computers. Just plug it into a USB port on your computer and enjoy better sound quality. The Link V2 is compatible with Mac, Windows and Linux systems.
xxx
Product typePortable DAC
Input1x USB-C
Output1x Jack 3.5mm
DAC chipCS43131
Output power80mW @ 32Ω
Frequency response20Hz ~ 20kHz (±0.5dB)
THD+N0.0018% @ 1kHz
SNR125dB
Crosstalk≥ 77dB
Supported sampling ratesPCM up to 32bit 384kHz, DSD up to DSD256
Cable length90mm
Dimensions60 x 13 x 7.2mm
Weight13g
ColorGray
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
Max sampling rateDSD256
ColorGray
2 reviews
excellent
tres bon dac son clair,tres detaille avec des casques de bonnes qualite (je possede l'hifiman sundara closed back et le sundara).
This review has been posted for XDUOO LINK V2 Portable USB DAC CS43131 32bit 384kHz DSD256 Gray
tres bon
son clair,assez fort indicateur pour les formats de codec rouge flac.mp3 vert pour hi-res.Tres bon bon dans l'ensemble
