XDUOO XD05 PLUS Battery-Powered Portable Headphone Amplifier AK4493EQ XMOS 32bit 384kHz DSD256 Silver
Direct successor to the XD-05, the xDuoo XD-05 Plus headphone amplifier with built-in DAC, it takes over the best features of its big brother while improving sound performances and connectivity. A particularly complete connection system that allows the XD-05 Plus to be adapted to all needs.
By buying this product you get 23 loyalty points
Reference : 14081
235,00 €tax incl.
195,83 € tax excl.
xDuoo XD05 Plus - silver
xDuoo XD-05 Plus Amplificateur Casque AK4493EQ XMOS 32bit 384kHz DSD256
Comfortable output power
With a power reserve of 1000mW at 32Ω, the XD-05 Plus has a comfortable power level that allows it to easily accompany many headphone models.
High performances components
The XD-05 Plus only integrates high quality, performance-oriented audio chips. It includes a digital-to-analog conversion chip AKM AK4493EQ and a USB XMOS XU208 interface, operating in asynchronous mode. The latter allow the support of high sampling rates, with PCM up to 32bit 384kHz and DSD up to DSD256.
Large autonomy
With its 3.8V / 5000mAh battery, the xDuoo headphone amplifier has no need to worry about its autonomy. This ensures that it operates for many hours before recharging.
USB : >=13h / SPDIF : >=21h / AUX : >=40h
A particularly complete connectivity
No matter which drive you are using, it is very likely that the XD-05 Plus can be adapted to it. Indeed, the latter offers a particularly complete panel of connectors for a portable amplifier: USB-C, Coaxial, Optical, Jack 3.5mm.
Dual clock
Always with the aim of providing the best possible sound reproduction, the xDuoo XD-05 Plus features two ultra-fable active phase noise clocks, operating with a CPLD. This combination allows a considerable reduction of the jitter, lowering it to a level at which it is undetectable.
High fidelity power supply circuit
The integrated filtering and high efficiency conversion circuitry optimizes the LDO circuit of the power supply to provide the DAC, LPF, amplification, USB interface and SPDIF receiver with an independent and clean power supply.
Interchangeable Dual OPA
The XD-05 Plus integrates a dual OPA mounted on a DIP8 bracket. It is therefore extremely easy to replace it with another model, without the need for welding, in order to enjoy a different sound.
Caution! Be careful when changing these components, as any improper handling that damages the device or OPA will void the warranty.
Optional Bluetooth
(Accessory sold separately)
Combined with the xDuoo 05BL Bluetooth module (sold separately), the XD-05 Plus becomes a true Bluetooth DAC Amplifier. It is thus possible to enjoy your music remotely and without any wires!
Output power1000mW @ 32Ω
Inputs1x Jack 3.5mm (line input)
1x USB-C
1x Mini Coaxial / Mini Optical
Output1x Jack 6.35mm
Frequency responseAMP : 10Hz ~ 100kHz (+/-0.5dB)
USB/SPDIF : 20Hz ~ 20kHz (+/-0.5dB)
Supported sampling ratesUSB : PCM up to 32bit 384kHz, DSD up to DSD256 (DoP and Native), DXD up to 32bit 384kHz
Optical/Coaxial : PCM up to 24bit 192kHz, DSD64
THD+NUSB/SPDIF inputs : 0.0016% @ 1kHz
AUX input : 0.0009% @ 1kHz
SNR117dB
Crosstalk>= 75dB
Battery3.8V, 5000mAh
AutonomyUSB input: >= 13h
SPDIF input: >= 21h
AUX input: >= 40h
Dimensions139 x 75.2 x 22.8mm
Weight276g
Housing materialAluminium
ColorSilver
InputJack 3.5mm
OutputJack 6.35mm
ColorSilver
ClassN/A
Direct successor to the XD-05, the xDuoo XD-05 Plus headphone amplifier with built-in DAC, it takes over the best features of its big brother while...
