ALPS ALPINE Digital Rotary Encoder 24 Positions Push-Button
This 24-position digital incremental encoder features a D Shaft for mounting a knob. It can be used as a volume control, or to adjust the level of audio, video or computer devices with a suitable programming chip (not supplied). The encoder also acts as a push-button, so it can also be used as a source selector, for example.
Reference : 19076
3,50 €tax incl.
2,92 € tax excl.
ALPS ALPINE Digital Rotary Encoder 24 Positions Push-button D Shaft 20mm
ALPS ALPINE Digital Rotary Encoder 24 Positions Push-button D Shaft 20mm : Front view
Type of productMechanical Encoder
Pulses per revolution24PPR
Number of notches24
OrientationVertical
Shaft length20mm
Shaft diameterØ6mm
Operating temperature-10°C / +70°C
Supply Voltage Max5V DC
TerminationSolder Pin
Push SwitchWith push-button switch
Encoder outputQuadrature
Encoder technologyMechanical
Encoder typeIncremental
Encoder mountingThrough Hole
Number of channels2
Shaft TypeD Type Flatted End
ShaftFlat
Channel2 (Stereo)
Resistance (Ohm)N/A
Tolerance (%)N/A
ALPS ALPINE Digital Rotary Encoder 24 Positions Push-Button D Shaft 20mm
This 24-position digital incremental encoder features a D Shaft for mounting a knob. It can be used as a volume control, or to adjust the level of...
