2-Way Motorized Potentiometer D-Log 100k
This ALPS RK16817MG potentiometer is ideal for integration into a HiFi device. Its motorization can offer the possibility of remote control via remote control. Compact and dust-resistant, this model has CI connections in series (two channels on a single level). Its curve is logarithmic (D-Log).
Product type | Motorized potentiometer |
Output | Stereo |
Mounting direction | Horizontal |
Shaft type | D-Shaft |
Shaft length | With screw thread: 25mm Without screw thread: 18mm |
Shaft diameter | 6mm |
Screw thread diameter | 9mm |
Total resistance | 100kΩ |
Resistance curve | 3B |
Motor voltage | 4 à 6VDC (standard: 4.5V) |
Potentiometer rotation speed | 12 +/-3s/300° (4.5VDC) |
Min / Max Operating temperature | -10°C / +70°C |
Total resistance tolerance | +/-20% |
Nominal power | 0.05W |
Max operating voltage | 50V AC |
Max attenuation | 100dB |
Insulation resistance | 100MΩ min. 250V DC |
Total rotation angle | 300° +/-5° |
Operating life | 15000 cycles |
Dimensions | 69.9 x 25 x 29.7mm |
