Bourns PTA6043 mono Potentiometer 10kohm 250mW
Reference : 11820
3,20 €tax incl.
2,67 € tax excl.
Shipping date: 25-04-2025.
This carbon track slide potentiometer is an original way to vary the audio volume over a 60mm stroke. This slide-type potentiometer "FADER" will lend itself to the design of amplifiers, audiobox, DIY audio dock. The applications range from car audio to the design of mixing tables and drum machines.
Technical characteristics :
  • Resistance: 10 kΩ
  • Load capacity: 250mW +/- 20%
  • Insulation resistance: <100 MΩ direct current
  • Test voltage: 250 VDC
  • Potentiometer travel: 60mm
  • Double cage
  • Track Type: Linear Mono
  • Metal body
  • Number of movements: 15000 cycles
  • Track linearity error: 3dB from -40dB to 0dB
ShaftFader
Channel1 (Mono)
Resistance (Ohm)10000.0
Tolerance (%)20
