Logarithmic Stereo Potentiometer 100K Ohm on PCB
This is a loudness stereo potentiometer with a 100kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of Ø6mm and a length of 20mm.
Reference : 16988
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 22-04-2025.
loundess Potentiometer on pcb
Stereo Potentiometer Notched Shaft High Quality 100kΩ
ALPS 50KA2 Potentiomètre Stéréo Axe Cranté Haute Qualité 50kΩ
This is a loudness stereo potentiometer with a 100kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of Ø6mm and a length of 20mm. It is pre-soldered to a PCB, with pre-soldered terminals for easy mounting.
Potentiomètre logarithmique Stéréo Axe Cranté 100K Ohm sur PCB
Product typeLoudness potentiometer
Resistance100kΩ
ChannelStereo (2)
Progress curveLogarithmic
Shaft typeNotched shaft
Shaft diameterØ6mm
Shaft length20mm
Total dimensions38x38x28mm
ShaftNotched
Channel2 (Stereo)
Resistance (Ohm)100000.0
Tolerance (%)N/A
This is a loudness stereo potentiometer with a 100kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of...
