Logarithmic Stereo Potentiometer 50K Ohm on PCB
This is a stereo potentiometer with a 50kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of Ø6mm and a length of 20mm.
Reference : 16991
12,90 €tax incl.
10,75 € tax excl.
Shipping date: 15-04-2025.
Potentiometer on pcb
Stereo Potentiometer Notched Shaft High Quality 50kΩ
PH2702 - A50K - Screw terminals
This is a stereo potentiometer with a 50kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of Ø6mm and a length of 20mm. It is pre-soldered to a PCB, with pre-soldered terminals for easy mounting.
Product typePotentiometer
Resistance50kΩ
ChannelStereo (2)
Progress curveLogarithmic
Shaft typeNotched shaft
Shaft diameterØ6mm
Shaft length20mm
Total dimensions35x30x28mm
ShaftNotched
Channel2 (Stereo)
Resistance (Ohm)50000.0
Tolerance (%)N/A
This is a stereo potentiometer with a 50kΩ resistor and a logarithmic progression curve. Its notched shaft has a diameter of...
