Amplifier chip
Class
Power (W)
30 - 950
Channel
Input
Output
Remote Control
Color
Marc A.
Mon lecteur réseau Teac NT 505 X possède une sortie casque 3,5mm à 4 pôles. Hors tous les jacks proposés en 3,5mm sont en 3...
superbe tube .fonctionnent très bien sur un Cayin cs150
.j aimerais savoir si ils sont disponible en quad appairés. Merci pour vos réponses..
alexandre G.
couplé a un streamer eversolo sur les liaisons symetriques... tout y est!
puissance , details , profondeur et le tout dans une...
Power amplifiers
In this category you'll find our selection of Power Amplifiers. Unlike integrated amplifiers, these only add power to the signal received, so they don't have built-in pre-amplification to concentrate on the very essence of amplification. Whether it's a Mono Power Amplifier or a Stereo Power Amplifier, find the ideal solution to perfect your HiFi installation.
  • Ref : 18897
    In Stock
    The Denafrips Hyperion is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. The Hyperion is capable of delivering 2x80W into 8Ω or 2x150W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped with 4 pairs of output transistors.
    1 600,00 € 1 333,33 €Ex.
    In Stock
  • Ref : 18911
    The Denafrips Thallo is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. This is an improved version of the brand's Hyperion model. The Thallo is capable of delivering 2x120W into 8Ω or 2x220W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped...
    2 450,00 € 2 041,67 €Ex.
    In Stock
  • Ref : 18908
    In Stock
    In Stock
  • Ref : 20203
    Eversolo has designed the AMP-F10 class AB power amplifier to accompany its new streamer, the DMP-A10. This amplifier features a dual mono balanced architecture with no less than 5 MOSFET transistors per channel. This architecture gives it a substantial power reserve, as it is capable of developing up to 2x320W under 4 ohm and 2x200W under 8 ohm. Added to...
    2 589,00 € 2 157,50 €Ex.
    In Stock
  • Ref : 18515
    In Stock
    The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a result, it offers a high energy reserve, great dynamics and a highly accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical...
    799,00 € 665,83 €Ex.
    In Stock
  • Ref : 19171
    In Stock
    The Fosi Audio V3 MONO is a compact, powerful but still affordable 1-way amplifier. Based on a TI TPA3255 amplifier chip, it can deliver 240W at 4Ω. Furthermore, this amplifier is equipped with a host of audiophile components such as Japanese and German Elna and Wima capacitors, respectively, or a duo of DIP8-mounted TI NE5532 OPAs, giving you the...
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 20713
    LAiV Audio Harmony GaNM power amplifiers represent excellence in power amplification, coming in the form of two mono blocks exploiting gallium nitride (GaN) transistors for 200W of amplification at 8Ω per block, offering uncompromising sound quality. The meticulous attention paid to every aspect of the Harmony GaNM, from its ultra-low-noise power...
    5 129,00 € 4 274,17 €Ex.
    In Stock
  • Ref : 20711
    In Stock
  • Ref : 17504
    Continuing the Element line's identity, the Matrix Audio Element P2 power amplifier inherits a sleek, modern design that integrates seamlessly with the other models in this family. Thanks to its highly efficient Class D architecture, it can easily be integrated into a system, providing significant power to your speakers.
    1 999,00 € 1 665,83 €Ex.
    In Stock
  • Ref : 17324
    The NAD M23 is a high-end power amplifier using Class D Eigentakt™ amplifier modules from Purifi. These, in addition to offering a consequent power that can reach 2x380W under 4Ω, ensure a perfectly linear frequency response whatever the load of the associated speakers. Moreover, they have incredible performance, with a particularly low level...
    3 799,00 € 3 165,83 €Ex.
    In Stock
  • Ref : 19750
    In Stock
    The Singxer SA-90 class A/B mono power amplifier delivers ultra-low-noise, ultra-low-distortion performance while offering no less than 200W output power at 4 ohms. Like most power amplifiers on the market, it adopts a monoblock design with a simple, minimalist look.
    699,00 € 582,50 €Ex.
    In Stock
  • Ref : 20393
    SMSL unveils its PA200, a singular amplifier somewhere between a power amplifier and an integrated amplifier. The latter is capable of operating both in stereo with volume control and in mono as a pure power amplifier, and relies on Infineon GaN FET transistors. It offers up to 2x160W under 4 Ohm power via its stereo RCA input, and up to 1x400W under 4...
    449,00 € 374,17 €Ex.
    In Stock
  • Ref : 18657
    Powerful Class A stereo power amplifier, the Tonewinner AD-1PA+ benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device,...
    3 590,00 € 2 991,67 €Ex.
    In Stock
  • Ref : 17768
    In Stock
  • Ref : 17769
    In Stock
    With the AD-2500 Pro, Tonewinner offers a particularly powerful stereo Class AB power amplifier. This one is indeed able to develop a power of 2x950W under 4Ω while offering a great dynamic range and ensuring a low noise level for a sound reproduction as precise as musical.
    1 690,00 € 1 408,33 €Ex.
    In Stock
  • Ref : 17346
    The Tonewinner AD-5100PA+ is a Class AB power amplifier featuring 5 channels capable of delivering 130W into 4Ω or 90W into 8Ω each. It is therefore an ideal model for integration into a home theater system. It uses 5 pairs of Toshiba TTC5200 and TTA1943 transistors, ensuring a musical and rich sound reproduction. The low-noise differential...
    629,00 € 524,17 €Ex.
    In Stock
  • Ref : 17354
    The Tonewinner AD-7300PA+ is a 7-channel Class AB power amplifier, ideal for home theater integration. Capable of developing significant power, measured at 584W RMS for one channel powered at 4Ω or 7x190W for 7 channels powered at 8Ω, this amplifier offers great dynamics and ensures low noise.
    2 049,00 € 1 707,50 €Ex.
    In Stock
  • Ref : 17407
    In Stock
    Tonewinner presents its AD-8300PA, an 11-channel power amplifier, allowing a home cinema integration, including Dolby Atmos systems. It delivers a consistent power with low distortion for an immersive and dynamic sound reproduction. Coupled with an audio/video preamplifier (sold separately), the AD-8300PA is an excellent solution for entering the world of...
    1 790,00 € 1 491,67 €Ex.
    In Stock
  • Ref : 19759
    In Stock
    The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 19764
    In Stock
    In Stock
  • Ref : 19588
    In Stock
    The Topping B200 power amplifier is a mono amplifier based on a discrete-component NFCA amplifier circuit. This enables it to achieve a considerable power level while maintaining excellent performance metrics. Indeed, the B200 is capable of delivering up to 200W of power (THD=1%) at both 4 ohms and 8 ohms.
    599,00 € 499,17 €Ex.
    In Stock
  • Ref : 19586
    In Stock
    In Stock
  • Ref : 17642
    The Topping PA7 is a powerful amplifier, based on a Class D architecture and benefiting from an intelligent and particularly careful design. It is thus capable of developing a significant power while maintaining a very low level of distortion. The technologies used ensure a clear, precise and deep sound reproduction. In addition, the balanced structure of...
    499,00 € 415,83 €Ex.
    In Stock
  • Ref : 17644
    In Stock
    In Stock
