AUDIO-GD HE-2 MK3 Power Amplifier Silver
With the HE-2 MK3, Audio-GD offers a pair of massive dual mono amplifiers capable of producing 500 W of power at 4 Ω, including 30 W in pure class A. This pair of amplifiers is distinguished by its use of a regenerative power supply as well as ACSS, Linear Fidelity and Non negative feedback technologies contributing to a more transparent sound reproduction with a very low level of distortion.
By buying this product you get 779 loyalty points
Reference : 19476
7 799,00 €tax incl.
6 499,17 € tax excl.
AUDIO-GD HE-2 MK3 Class A Dual Mono Power Amplifier 2x500W 4 Ohm Silver
AUDIO-GD HE-2 MK3 : Front view
With the HE-2 MK3, Audio-GD offers a pair of massive mono power amplifiers, for the integration of a high-end dual mono HiFi amplification system capable of producing 500W of power at 4Ω per channel, including 30W in pure Class A. This pair of amplifiers features a regenerative power supply as well as ACSS, Linear Fidelity and Non Negative Feedback technologies, contributing to a more transparent sound reproduction with very low distortion levels.
Audio-GD HE-2 MK3: Regenerative power supply
The power supply for Audio-GD's HE-2 MK3 is based on a set of 4 transformers per unit, 3 of which are regenerative, making a total of 8 transformers for a total of 2,000 W and an electrical capacity of 260,000 uF. The main advantage of the regenerative transformers is their ability to "self-power". In fact, this type of power supply has the ability to act as both a source and a load of current. In this way, these transformers can use excess energy not used by the system to feed it back into the system, thereby limiting the device's actual power consumption. Furthermore, the power supply stage of the HE-2 MK3 has a very high input impedance to avoid mains disturbance, and a fast, low impedance, high linearity output, making it a high quality power supply.
AUDIO-GD HE-2 MK3: ON Semiconductor transistors
Audio-GD HE-2 MK3: Massive power output
The amplification stage of Audio-GD's HE-2 MK3 uses 40 ON Semiconductor transistors per unit for an output power per channel of 30 W in pure class A and 500 W at 4 Ω. Furthermore, signal gain is managed in current rather than voltage, resulting in unrivalled precision and ultra-low distortion. It's also worth noting that you can choose between +20dB and +26dB of gain to best adapt the signal to your speakers.
Audio-GD HE-2 MK3: ACSS
Audio-GD has its own signature technology, called ACSS for "Audio-GD Current System Signal". Thanks to the firm's expertise and know-how, this technology offers a sound that is less coloured, more detailed and of unrivalled neutrality. Each of the firm's technical engineers is not only highly experienced, but is also a HiFi and audio enthusiast like you and us.
AUDIO-GD ACSS
HE-2 MK3, Audio-GD : Linear Fidelity & Non Negative Feedback
Finally, for its HE-2 MK3 dual mono amplifier, the brand incorporates Linear Fidelity technology in the output circuits and Non Negative Feedback in the amplifier as a whole. This special design produces a linear response curve and a very low level of distortion, for extremely transparent sound reproduction, whatever the output level and frequency reproduced.
Product typePower amplifier
InputsXLR
ACSS
OutputSpeaker terminals
Amplification classClass A
Output power> 250W @ 8ohm
> 500W @ 4ohm
> 1000W @ 2ohm
Gain20dB
26dB
Frequency response20Hz - 100KHz (-dDB)
Input sensitivityXLR: 2.2V RMS
ACSS: 2mA RMS
Input impedanceXLR: 94KΩ
ACSS: < 10Ω
Total harmonic distortion more noise (THD)0.03% @ 10W 8Ω
0.04% @ 50W 8Ω
0.05% @ 100W 8Ω
Signal-to-noise ratio (SNR)> 120DB
Channel imbalance< 0.01DB
Weight85kg
ColorSilver
Package2x Audio-GD HE-2 MK3 mono power amplifier
2x Power cable
InputACSS
InputXLR
ColorSilver
Channel2 (Stereo)
ChannelDual Mono
ClassClass A / AB
Amplifier chipTransistors
Power (W)500.0
With the HE-2 MK3, Audio-GD offers a pair of massive dual mono amplifiers capable of producing 500 W of power at 4 Ω, including 30 W in...
