AUDIO-GD MASTER 2H Class-A Balanced Dual Mono Amplifier ACSS 2x 250W / 8 Ohm
The Master 2H is a dual mono balanced power amplifier, incorporating a particularly neat architecture and ensuring robustness.
KEY POINTS :
  • 2x250W 8 Ohms / 2x500W 4 Ohms
  • Double Mono
  • Balanced
  • Floor entry and gain Class A
  • ACSS inputs
By buying this product you get 404 loyalty points
Reference : 10211
4 049,00 €tax incl.
3 374,17 € tax excl.
Including 1,00 € for green tax
AUDIO-GD MASTER 2H
Power Amplifier / Double Mono / Symmetrical
An exceptional Mono Double Amplifier ...
Once again, Audio-GD presents the quintessence of audio technology with this dual-mono amplifier with a particularly neat architecture and formidable robustness.
The famous brand offers us here an amplifier with a new output stage (identical to that of the HE-2) in the most accomplished form with outstanding performance: it delivers 2x 250W under 8 Ohm, and 2x 500W under 4 Ohm.
Each product of the brand is scrupulously tested from every angle with one of the most powerful systems in the world: the Audio Analyzer 2700 Series from Audio Precision.
A clean and efficient connectivity
The Master 2H, composed of 2 separate blocks, has a total of 4 analog inputs: 2x XLR and 2x ACSS. Outputs are of course on 2 terminals HP, where you just have to connect your speakers to enjoy.
The result is simple: a great musicality, thanks to an exceptional dynamic and an extremely rich sounddetailed in all respects.
Audio-GD Master-2H
A formidable HiFi device
Class A Symmetrical / R-Core / ACSS / Double mono
This Master 2H is equipped with no less than 4 transformers including 2 R-Core for a total of 6000W, 260.000uF very high-end Nover capacitors, and 80 very high performance MJL1302 / 3281 transistors for the output stage .
This amplifier is also designed around a Class A discrete balanced input and gain stage, with separate Class A power supply for the left and right channels and no capacitors or AOPs on the signal path.
The output transistors work with a large quiescent current. The "Diamond Cross" output stage avoids crossover distortion as well as a Class A amplifier.
Audiophile grade components, including DALE resistors, WIMA capacitors, and NOVER electrolytics.
Audio-GD MASTER-2H
Class A
Class A
Class A has the particularity of having its active components still in conduction. The quiescent current remains higher than the output current, thus limiting the harmonic distortion. The signal coming out of the 2A is therefore of excellent quality, due to the absence of this famous crossing distortion of the alternations of the sinusoids.
ACSS Technology
Audio-GD has its own technological signature, called ACSS for "Audio-GD Current Signal System".
This technology allows a simpler and more direct input stage, reducing distortion.
Thanks to the expertise and know-how of the firm, this technology offers a less colorful sound, more detailed, and unparalleled neutrality.
ACSS
Output power2x250W under 8 Ohm / 2x500W under 4 Ohm
Output voltage58V RMS
Input sensitivity94K Ohm (XLR) / <10 Ohm (ACSS)
Frequency response20Hz - 20kHz to 0.01dB (XLR 8 Ohm) / 10Hz - 100kHz to -3dB (XLR 8 Ohm)
SNR> 120dB
inputs2x XLR / 2x ACSS
Exits2x Stereo terminal blocks (accepting bananas)
Food4 transformers, including 2 R-Core
Various
Consumption250W
Weight70kg (both blocks)
Housing material100% Aluminum
Dimensions340 x 260 x 450mm (one block)
Accessories2x Power cable (only for testing The manufacturer recommends using appropriate power cables for this product)
The button on the back allows selection of XLR input or ACSS input
InputXLR
InputACSS
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)250.0
Des amplis réellement au plus haut niveau
Autant le dire tout de suite, ces amplis monauraux construits radicalement à l’ancienne (circuits symétriques, composants discrets, quasi-classe A) avec une originalité de transmission du signal musical interne par l’intensité du courant et non son voltage (technologie ACSS similaire aux amplis Krell) sont au niveau des meilleurs amplis que j’ai eu l’occasion d’écouter (chez des particuliers ou des salons Hi-Fi). Ils sont exceptionnels et je pense au niveau de ce qui se fait de mieux au monde, mais à des prix 20 fois supérieurs !
La précision, le raffinement des timbres, la présentation spatiale de la scène musicale sont tout simplement les meilleures que je connaisse. On a l’impression de pouvoir toucher la musique, les musiciens et les chanteurs, et ceci sur tous les genres musicaux. Même un orchestre symphonique passe d’une manière comparable à ce que j’entends en concert.
La dynamique est époustouflante. La profondeur des basses incroyable et l’équilibre global à mourir. La musique est douce et ferme à la fois. Les aigus précis, jamais agressifs. La musique coule…
Ces amplis ont littéralement transformé mes enceintes Triangle Magellan, en les rendant encore plus précises, plus vivantes et naturelles. Je ne pensais pas pouvoir obtenir chez moi pareille expérience musicale. C’est à pleurer et mes enceintes me chantent des remerciements. Ma chaîne sonne aussi bien que les meilleures chaines que j’avais entendues jusqu’ici… et c’est chez moi !!! Je n’en rêvais même pas. Le cœur en est ces amplis, la voix mes Magellan. C’est d’une beauté…
Ce Master-2H fonctionne à merveille avec mon Master-11.
En toute sincérité, si vous pouvez vous offrir ces 2 blocs, n’hésitez pas. Ce sont des chefs-d’œuvre. Merci à Audio-GD. Kingwa est un génie de l’amplification ! et merci à Audiophonics de commercialiser ces appareils en France.
 (25)
 (4)
This review has been posted for AUDIO-GD MASTER 2H Class-A Balanced Dual Mono Amplifier ACSS 2x 250W / 8 Ohm
The Master 2H is a dual mono balanced power amplifier, incorporating a particularly neat architecture and ensuring robustness. KEY POINTS :...
