AUDIO-GD MASTER 3A Power Amplifier Pure Class A Balanced ACSS 2x180W 4 Ohm
The Audio-GD Master 3A takes the excellent base of the Master-3, this time in a pure Class A model capable of delivering 2x180W of power at 4 Ohm. This version also offers a slightly smoother and warmer sound signature.
By buying this product you get 289 loyalty points
Reference : 15340
2 890,00 €tax incl.
2 408,33 € tax excl.
AUDIO-GD Master 3A
Balanced Pure Class A Amplifier ACSS 2x180W 4 Ohm
Audio-GD MASTER-3A
Master 3A Version
A sublime amplifier in every way...
Audio-GD presents us once again the quintessence of technology in audio with this amplifier with a more than neat and clean architecture.
The famous brand of high fidelity audio offers us here an amplifier in the most accomplished form possible with outstanding performances: it delivers 2x90W under 8 Ohm, and 2x 180W under 4 Ohm.
Each product of the brand is scrupulously tested with one of the most powerful systems in the world: the Audio Analysers 2700 Series from Audio Precision.
Linear Fidelity & Non Negative Feedback
The brand integrates Linear Fidelity technology to the output circuits and Non Negative Feedback to the amplifier in general. This particular design makes it possible to obtain a linear response curve as well as a very low level of distortion, for a sound restitution of a very great transparency and this whatever the output level and the reproduced frequency.
Uncluttered and incredibly efficient connectivity
The Master 3A has 4 analog inputs: 2x XLR and 2x ACSS. The output is of course on 2 speaker terminals, where you just have to plug your speakers to enjoy.
The result is simple: great musicality, thanks to exceptional dynamics and a rich sound that is extremely detailed at all points.
Audio-GD Master-3
A clean and precise HiFi device
Balanced Pure Class A / R-Core / ACSS
This Master 3A is equipped with no less than 4 transformers including 2 R-Cores for a total of 1600W, 140.000uF of high end Nover capacitors, and 24 high performance ON Semiconductors for the output stage.
This amplifier is also designed around a pure Class A ACSS discrete balanced circuit, with a separate power supply to avoid any interference or electromagnetic disturbances on the signal.
Audio-GD MASTER-3A
Class A
Pure Class A
A class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thus limiting the harmonic distortion on the output signal. The output signal of the Master 3A is therefore of excellent quality, due to the absence of this famous sinusoidal crossing distortion.
ACSS Technology
Audio-GD has its own signature technology, called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and the know-how of the firm, this technology offers a less colored, more detailed sound, and of an unequalled neutrality. Each technical engineer of the firm is, in addition to being very experienced, a HiFi and audio enthusiast like you and us. To know, when the ACSS output is used, the XLR and RCA outputs are switched to MUTE.
ACSS
Product typeAmplifier
Output power2x90W @ 8 Ohm
2x180W @ 4 Ohm
2x 360W @ 2 Ohm
SNR> 110dB
Gain+26dB
Input sensitivityXLR : 1.4V RMS
ACSS : 2mA RMS
Crosstalk> -120dB
Inputs2x XLR
2x ACSS
OutputsStereo speaker terminals
Supply voltage220-240V AC 50/60Hz
Consumption300W
Transformers power1600W
Housing materialAluminum
Dimensions48 x 44 x 19cm
Weight40kg
InputACSS
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)180.0
2 reviews
ENCHANTEE
Très contente de cet achat, la classe A ça s'entend, !..
2x50w sous 8 ohms , garantis en classe A, c'est suffisant .
Même pour maitriser mes enceintes ELIPSON Legacy 3230, qui descendent pourtant assez bas en impédance, et dans les basses.
Associé à un préampli MUSICIAN MONOCEROS, avec utilisation de ses sorties Symétriques et des entrées symétriques, bien sûr, de l'ampli AUDIO GD. C'est peut être le petit reproche à faire à cet ampli, de ne pas posséder d'entrés RCA. Mais AUDIO GD a également une autre entrée "en modulation de courant" ICSS , redoutable parait il...(il faut acheter le préampli associé, de la marque AUDIO GD )pour pouvoir utiliser cette liaison ICSS...Marketing, marketing.!!..)
SUPER PRODUIT.
This review has been posted for AUDIO-GD MASTER 3A Power Amplifier Pure Class A Balanced ACSS 2x180W 4 Ohm
MUSICALITE ET PRECISION
Une belle expérience, que l'écoute de ce magnifique amplificateur.
Raccordé à un préampli MUSICIAN Monoceros, le résultat est excellent. Le différents registres musicaux sont présents, et fouillés, sans tomber dans un coté "ultra". La musique est belle, douce mais punchy à la fois...Un ampli a tube (j'en ai un) se justifie t il encore, au vu de l'évolution des "transistors" ?
The Audio-GD Master 3A takes the excellent base of the Master-3, this time in a pure Class A model capable of delivering 2x180W of power at 4 Ohm....
