AUDIOPHONICS AP300-S2503E Power Amplifier 3E AUDIO 260-2-29A PFFB
The Audiophonics AP300-S2503E is a stereo power amplifier featuring a 3e Audio PFFB amplifier module. This enables it to develop 2x250W of power under 4Ω while delivering exceptional sound quality, combining precision and dynamics. All components are assembled - in a magnificent, sturdy aluminum case with acrylic front panel - by hand in our workshop in France.
Reference : 18567
499,00 €tax incl.
415,83 € tax excl.
Audiophonics Workshop amplifiers range
Audiophonics AP300-S2503E Amplificateur de puissance Class D stéréo 3e Audio 2x250W 4Ω
Audiophonics AP300-S2503E : Main view
Audiophonics AP300-S2503E : Points clés
Audiophonics AP300-S2503E : 3e Audio PFFB Amplifier Module
The heart of the Audiophonics AP300-S2503E is its 3E AUDIO 260-2-29A PFFB amplifier module. This amplifier is based on a meticulous Class D architecture, enabling it to develop a comfortable 2x250W of power under 4Ω. Power that goes hand in hand with sound reproduction of great precision and richness. To achieve this, the module uses an advanced feedback design (Post Filter Feedback) as well as a proprietary error correction system (PurePath™ Ultra-HD). The latter enables it to achieve an extremely low level of distortion across the entire frequency band, enhancing its sound quality.
Audiophonics AP300-S2503E : 3e Audio PFFB amplification board
Audiophonics AP300-S2503E : Mornsun LOF550-20B48 power supply module
Audiophonics AP300-S2503E : Mornsun LOF550-20B48 Power Supply Module
The power supply stage of the AP300-S2503E incorporates a Mornsun LOF550-20B48 switching power supply module. This uses high-quality components to deliver a clean, stable electrical signal to the amplifier module, an essential step in ensuring transparent, accurate sound reproduction.
Audiophonics AP300-S2503E : Simple, effective connectivity
The Audiophonics AP300-S2503E is equipped with simple, effective connectors. Its rear panel features a single balanced XLR input. Output is via speaker terminals that accept bare cables, forks and bananas. Finally, a 3.5mm jack is also provided for the device's 5-12V trigger, enabling automatic switching on and off of the various devices in your audio system.
Audiophonics AP300-S2503E : Rear panel and connectors diagram
1Entrée symétrique XLR
2Trigger
3Sortie enceinte canal droit
4Sortie enceinte canal gauche
5Connecteur d'alimentation
6Fusible
7Bouton de mise sous tension
Audiophonics AP300-S2503E : Robust chassis & modern design
The Audiophonics AP300-S2503E components are housed in a beautiful black aluminum case with acrylic front panel. Recessed side panels and various holes on, under and behind the unit ensure efficient heat dissipation. Compact, the AP300-S2503E will slip effortlessly into your audio system or TV cabinet, for example.
Product typePower amplifier
Amplification typeClass D
Number of channelsStereo (2)
Output power2x250W @ 4Ω, 1% THD+N
2x180W @ 6Ω, 1% THD+N
2x150W @ 8Ω, 1% THD+N
Input1x Balanced stereo XLR
OutputsSpeaker terminals
Trigger5-12V
THD+N0.0007% @ 4Ω, 1kHz, 5W
Output noise18µV
Dynamic range125dB
Frequency response20Hz - 20kHz ±0.5dB
Nominal gain20.5dB
Input impedance20kΩ
Output impedance10mΩ
Supply voltage230VAC / 110VAC (auto switch)
Total dimensions (WxDxH)300 x 248 x 62mm
Weight2.35kg
Housing materialBody: Aluminum
Front panel: Acrylic
Package1x Audiophonics AP300-S5003E
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3255
Power (W)250.0
Excellent
Je l’ai acheté pour driver mes Golden Ear BRX, ça matche ! De la finesse, précision, richesse des timbres, de la dynamique, l’image stéréo et la spatialisation sont magnifiques , ça coche toute les cases à mon goût. Encore une magnifique réalisation d’Audiophonics , merci pour cette réalisation à tarif contenu, permettant aux mélomanes a budget contenu de profiter de pouvoir assouvir leur passion sans se ruiner !
This review has been posted for AUDIOPHONICS AP300-S2503E Class D Stereo Power Amplifier 3E Audio PFFB 2x250W 4 Ohm
The Audiophonics AP300-S2503E is a stereo power amplifier featuring a 3e Audio PFFB amplifier module. This enables it to develop 2x250W of power...
