AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels NCore NC252MP
The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home theater perfectionists who want to equip themselves with a foolproof amplification solution, with a good power reserve and impeccable linearity.
By buying this product you get 149 loyalty points
Reference : 18830
1 490,00 €tax incl.
1 241,67 € tax excl.
Shipping date: 29-04-2025.
Audiophonics HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 OhmAudiophonics HPA-H250NC : Main view
The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular at audiophiles and home theater perfectionists who want to equip themselves with a foolproof amplification solution, with a good power reserve and impeccable linearity. The 6 channels of this amplifier can, for example, be used to integrate a high-performance 5.1 home theater system. What's more, the NCore modules offer exceptional performance for sound reproduction of breathtaking accuracy and dynamics.
All modules and components are housed in a sober, modern and robust 100% aluminum case, with openings and radiators to promote heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics HPA-H250NC : Key features
Audiophonics HPA-H250NC : NCore NC252MP Amplifier Modules
Audiophonics HPA-H250NC : Three Hypex NCore NC252MP modules
The amplifier stage of the Audiophonics HPA-H250NC uses three Hypex NCore NC252MP modules. These Class D amplifiers offer excellent sonic performance and versatility. They deliver a very comfortable 6x250W at 4 Ohm or 6x150W at 8 Ohm, while benefiting from the high efficiency of this type of architecture.
The main features of these modules are their flat frequency response whatever the load impedance, their almost frequency-independent distortion level, and their ability to reject EMI interference. Their operation is based on a self-oscillating loop controlled by phase shifting, taking into account feedback only at the speaker output.
Audiophonics HPA-H250NC : NCore technology
NCore amplifiers are the first Class D amplifiers not only to approach the performance of operational amplifiers, but also to surpass them in terms of sound reproduction quality. They deliver clear, rich, musical sound in a compact package. This NCore technology combines the stability of Hypex UcD amplifiers with lower distortion and output impedance.
AUDIOPHONICS HPA-H250NC : NCore technology
Audiophonics HPA-H250NC : SMPS power supply
NC252MP modules also incorporate the power supply stage. This consists of a regulated half-bridge switched-mode power supply (SMPS) with synchronous rectification on the main output rails. Compact, powerful and efficient, this power supply is particularly well suited to cleanly powering a Class D amplifier.
What's more, to offer complete compatibility with the voltages delivered by different electrical networks, the power supply is equipped with an automatic input voltage doubler. The NC252MP module also features an overload protection system.
Audiophonics HPA-H250NC : Integrated SPMS power supply
Audiophonics HPA-H250NC : Connections
With its 6 channels, the HPA-H250NC amplifier provides 6 XLR inputs. Outputs are simply made via speaker terminals, which accept stripped cables, banana plugs or forks. Two 5-12V trigger connectors in 3.5mm jack format enable the amplifier's automatic switch-on to be controlled when integrated into a compatible system.
Audiophonics HPA-H250NC : Schéma connectique
1ON/OFF button
2Power connector
3cTrigger input
4Speaker outputs
5Fuse
6Trigger output
7XLR inputs
Product typePower amplifier
Number of channels6
Amplification typeClass D
Amplifier modules3x Hypex NCore NC252MP
Output power (@ THD 1%)6x 150W @ 8Ω
6x 250W @ 4Ω
6x 180W @ 2Ω
Inputs6x XLR
OutputsSpeaker terminals
THD+N0.0015%
SNR121dB
Output noise30µV
Output impedance1.5m
Frequency response10Hz - 50kHz
Efficiency92%
Input sensitivityMaximum power at 1.66Vrms
Trigger5-12V
Supply voltage110-230VAC
Idle power consumption0.1W
Dimensions413 x 322 x 60mm
Weight6.5kg
Package1x Audiophonics HPA-H250NC
1x Power cable
Audiophonics HPA-H250NC : Mesures THD+N vs Puissance Audiophonics HPA-H250NC : Mesures THD+N vs Puissance
Audiophonics HPA-H250NC : Mesures impédance de sortie
Audiophonics HPA-H250NC : Mesures THD+N vs Fréquence
Audiophonics HPA-H250NC : Mesures Réponse en fréquence
Audiophonics HPA-H250NC : Mesures distorsion d'intermodulation
InputXLR
OutputSpeaker terminal
Channel6
Amplifier chipHypex NCore NC252MP
Power (W)250.0
3 reviews
Excellent amplifier
Excellent amplifier. The only missing features are switchable RCA inputs and possibly adjustable gain (but that would be probably complicated and significantly more expensive with NC252MP modules).
This review has been posted for AUDIOPHONICS HPA-H250NC Power Amplifier 6 Channels Class D Ncore NC252MP 6x250W 4 Ohm
Excellent ampli
Utilisé sur 5 canaux avec mes enceintes LCR Kef LS50 Meta, R2 et 2 bass shakers BST-300ex.
Un seul souci a déploré : l'appareil était allumé en permanence, même « éteint ».
Après un bref échange, le SAV conclu qu'un relais était collé. Ampli expédié le lundi et récupéré le samedi, sans frais. Aucun problème depuis.
Ampli class D
j'ai attendu un moment pour donner mon avis.
Ce qui ne va pas : à quoi sert l'inter M/A l'appareil est toujours sous tension sifflement dans les tweeters dès la coupure du bouton M/A , j'ai été obligé de mettre une barrette avec inter M/A
A par ça le son de cet appareil est magnifique un pur régal pour moi le meilleur amplificateur que j'ai eu jusqu'à présent et j'en ai eu beaucoup classe AB, classe A et tubes mais jamais de class D.
j'écoute de la musique maintemant je me pose plus de questions
The Audiophonics HPA-H250NC is a 6-channel Class D power amplifier based on three Hypex NCore NC252MP modules. This version is aimed in particular...
