By buying this product you get 249 loyalty points
This product has been replaced by a revised version, the AUDIOPHONICS HPA-Q400ET 4-Channel Class D Amplifier Purifi.
This device is supplied as stan1ET400A,dard in 230V. If you need 110V input voltage, please specify it clearly in the comment field when ordering.
Power Amplifier PURIFI 4x400W 4 Ohm
We are proud to present AUDIOPHONICS HPA-SQ00ET, a class D 4 way power amplifier based on 4x PURIFI 1ET400A modules. This ready-to-use version is designed for audiophiles and home-cinema lovers in need of a foolproof amplification solution, with a considerable power reserve as well as impeccable linearity. The PURIFI modules are indeed among the most rigorous Class D amplification solutions on the market, with simply exceptional measured performance.
This device offers high level sound reproduction which will be suitable to drive demanding speakers, to sonorize large listening rooms or for studio applications requiring a considerable headroom without compromising on the precision and richness of the audio message.
All of the components are integrated in a sober and robust 100% Aluminum housing with openings and heatsinks to help heat dissipation. Its design also allows it to block signal interference.
The SMPS1200 switching power supply is a model with very high maximum output power of 1200 Watts. It has been specifically designed and developed by Hypex to provide 2 x 64V voltage required for operation of the most demanding amplifier modules.
This low noise high quality Power supply, meets every energy needs of the amplification modules.
Both modules are driven in opposite phase, to cancel out the «Power-Supply Pumping» effect. This allows greater stability in the power supply by alternately distributing current draws on each rail, thus increasing its overall capacities.
We opted for a regulation with two voltage levels in order to optimize the power supply to the PDOs and the auxiliary voltage supplied to the modules. This allows the OPAs to be powered with a high voltage (18V) for better overall performance, and allows them in turn to provide the voltage needed to reach the amplifier's maximum output level. While still maintaining the auxiliary voltage required by the modules.
Each channel uses its own Texas Intruments LM4562 AOP. bringing precision and musicality. They are mounted on a socket allowing their possible replacement.
To suit all uses we opted for 3 gain settings, adjustable by jumper on the interface card:
Efficient and versatile HPA-Q400ET Purifi amplifier has four inputs XLR connector with four pairs of speaker output terminals. It thus covers all cases, listening to high-fidelity home theater multi-purpose through bi-amplification.
Type | Power Amplifier |
Output power (max) | 8Ω @1%THD : 227W 4Ω @1%THD : 425W 2Ω @1%THD : 450W |
THD+N | PO=1W, f=1kHz 0.0007 % PO=10W, f=1kHz 0.00026 % PO=100W, f=1kHz 0.00015 % PO=1W, f=20-20kHz 0.0007 % PO=10W, f=20-20kHz 0.00029 % PO=100W, f=20-20kHz 0.00017 % |
IMD (CCIF) | PO=1W, f=18kHz+19kHz 0.00025 % PO=10W, f=18kHz+19kHz 0.00022 % PO=100W, f=18kHz+19kHz 0.00027 % |
IMD (DIM) | PO=1W, DIM30 0.002 % PO=10W, DIM30 0.002 % PO=100W, DIM30 0.002 % |
Idle noise | A-weighted 11.5 µV |
Dynamic range | A-weighted 4Ω 131 dB |
SNR | A-weighted 4Ω 131 dB |
Frequency response | RL= 8Ω, f= 20-20kHz ±0.01 dB RL= 4Ω, f= 20-20kHz ±0.01 dB RL= 2Ω, f= 20-20kHz ±0.01 dB |
Output impedance | 1kHz, Iout=1A 0.07 mΩ 20-20kHz, Iout=1A <0.65 mΩ |
Input impedance | RCA: 47kΩ / XLR: 94kΩ Bypass: 2.2kΩ / 4.4 kΩ |
Power supply | 230V (110V on request) |
Dimensions | 413 x 322 x 60mm |
Weight | 5.63 kg |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 4 |
Class | Class D / T |
Amplifier chip | Purifi 1ET400A |
Power (W) | 400.0 |
Average votes 5.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lammert S.
Neil M.
Max Z.
Cedric C.
