AUDIOPHONICS HPA-Q450ET Power Amplifier Four Channel
The Audiophonics HPA-Q450ET power amplifier is based on a Class D architecture, using four Purifi 1ET6525SA amplifier modules, two Hypex SMPS1200A400 power supplies and an Audiophonics custom buffer stage, enabling the amplifier to deliver incredible performance. This four-channel version is aimed at audiophiles and home theater perfectionists looking for a foolproof amplification solution, with considerable power reserve and impeccable linearity. Like all Audiophonics Workshop products, the HPA-Q450ET is meticulously designed and hand-assembled in our workshop in France.
By buying this product you get 249 loyalty points
Reference : 20248
2 490,00 €tax incl.
2 075,00 € tax excl.
Shipping date: 16-04-2025.
Audiophonics Workshop amplifiers range
This device is supplied as standard with 230V. For a 110V supply voltage, a jumper per supply is supplied and must be fitted.
Audiophonics HPA-Q450ET Power Amplifier Class D Four Channel Purifi 1ET6525SA 4x450W 4 Ohm
Audiophonics TPA-Q450ET : Front view
The Audiophonics HPA-Q450ET is a powerful, robust and extremely precise amplification solution. It is capable of powering demanding HiFi or home theater audio systems, while delivering sound reproduction of incomparable finesse, rich in detail and perfectly transparent. There's no compromise here between power and sonic precision. The on-board Purifi modules feature a particularly rigorous design, delivering exceptional measured performance.
With its four channels, the HPA-Q450ET is ideal for integration into a home theater system, providing power for front speakers, a center channel and a passive subwoofer.
All elements and components are integrated into a sturdy, solid aluminum housing with a modern, uncluttered design. This chassis also features openings and heat sinks on the sides to dissipate heat efficiently. What's more, its design effectively limits the impact of interference on the audio signal.
Audiophonics HPA-Q450ET : Key features
Audiophonics HPA-Q450ET : Purifi 1ET6525SA amplification module
Audiophonics TPA-Q450ET: Purifi 1ET6525SA amplification modules
Each channel of the Audiophonics HPA-Q450ET amplifier circuit is equipped with its own Purifi 1ET6525SA amplifier module. These use high-performance Class D architecture, with available power of 4x450W into 4Ω or 4x230W into 8Ω (at 1% THD) and high efficiency of over 94%. They also guarantee a very low level of THD, intermodulation distortion and noise, for a rich, precise and perfectly transparent sound reproduction, perfectly respecting the original audio signal to reproduce your music with unequalled fidelity and without coloration. It also guarantees a wide, realistic sound image, for perfect immersion.
Purifi's ongoing research into non-linear control theory has led to the development of the first mathematically accurate large-signal model for self-oscillating amplifier controllers. This breakthrough enables the feedback circuit to be fully optimized, resulting in a significant performance improvement over other designs. What's more, these Purifi 1ET6525SA modules feature a complete protection system for enhanced durability.
Audiophonics HPA-Q450ET: Hypex SMPS1200A400 power supply modules
The power supply stage of the Audiophonics HPA-Q450ET uses two ultra-high-efficiency Hypex SMPS1200A400 switch-mode power supply modules, each capable of developing 1200W of power. These have been specifically designed and developed by Hypex to provide the voltage required for optimal operation of the amplifier modules.
This high-quality, low-noise power supply perfectly meets the energy requirements of the Purifi 1ET6525SA amplifier modules. What's more, the amplifier modules themselves have an excellent ability to reject power supply noise. As a result, the HPA-Q450ET is highly insensitive to power grid imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics HPA-Q450ET : Hypex SMPS1200A400 power supply module
Audiophonics HPA-Q450ET: Proprietary “Buffer” interface card
The four amplifier modules are driven in phase opposition to cancel the Power Supply Pumping effect. This makes for greater power supply stability, alternately distributing current calls on each rail and thus increasing its capacity. A two-level voltage regulation is used to optimize the power supply to the AOPs and the auxiliary voltage supplied to the modules. One Audiophonics OPA1656 AOP is used per channel. These are very low-distortion PDUs, offering the highest transparency with very low THD. They are mounted on a socket so they can be replaced if necessary.
In addition, a gain control is located on the underside of the unit to suit all applications. Four gain settings are available: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics HPA-Q450ET: Balanced connectors
The Audiophonics HPA-Q450ET features balanced inputs on XLR connectors. At the output, Audiophonics insulated terminal blocks (developed in partnership with AEC Connectors) with 24k gold-plated contacts ensure an excellent connection between amplifier and loudspeakers. A 5-12V trigger module with input and output allows the amplifier to be integrated into an automatic on/off chain for your entire audio system.
With its four channels, the HPA-Q450ET can be used in both HiFi and home theater systems. In the latter case, it can perfectly power two front speakers, a center speaker and a passive subwoofer.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Audiophonics HPA-Q450ET : Amplifier diagram
1ON/OFF button
2Speaker output
3Speaker output
4Power input
55-12V trigger input
6Speaker output
7Speaker output
8Balanced XLR input
9Balanced XLR input
10Fuse
115-12V trigger output
12Balanced XLR input
13Balanced XLR input
THD vs Fresuency @ 4Ω
Audiophonics HPA-Q450ET : THD vs Frequency curve
THD+N vs Power @ 1kHz
Audiophonics HPA-Q450ET : THD+N vs Power curve
Frequency response @ 2.83V
Audiophonics HPA-Q450ET : Frequency response curve
Product typePower amplifier
Amplifier modules4x Purifi 1ET6525SA
Amplification typeClasse D
Number of channels4 channels
Output power4x230W @ 8Ω, 1% THD
4x450W @ 4Ω, 1% THD
4x510W @ 2Ω, 1% THD
Efficiency> 94%
Inputs4x Balanced XLR
OutputsSpeaker terminals
TriggerInput / Output 5-12V on Jack 3.5mm mono
THD+N0.00035% @ 1W, 1kHz
0.0001% @ 10W, 1kHz
0.00005% @ 100W, 1kHz
0.00035% @ 1W, 20Hz-20kHz
0.00029% @ 10W, 20Hz-20kHz
0.0001% @ 100W, 20Hz-20kHz
IMD (CCIF)0.0000003% @ 1W, 18.5kHz+19.5kHz
0.0000006% @ 10W, 18.5kHz+19.5kHz
0.0000005% @ 100W, 18.5kHz+19.5kHz
IMD (DIM)0.002% @ 1W, DIM30
0.002% @ 10W, DIM30
0.009% @ 100W, DIM30
Idle noise (ICN)6.6µV @ A-wt
Dynamic range137dB @ A-wt
SNR137dB @ A-wt
Frequency response±0.01dB @ 8Ω, 20Hz-20kHz
±0.01dB @ 4Ω, 20Hz-20kHz
±0.01dB @ 2Ω, 20Hz-20kHz
Input impedance20kΩ
Output impedance0.03mΩ @ 1kHz, 1A
< 0.35mΩ @ 20Hz-20kHz, 1A
Gain / Input sensitivity for max power at  1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
Tension d'alimentation230V AC (switchable to 110V AC via internal jumper)
Housing materialAluminum
Total dimensions (WxDxH)435 x 355 x 73mm
Weight6.91kg
Package1x Audiophonics HPA-Q450ET
1x Power cable
InputXLR
OutputSpeaker terminal
Channel4
Amplifier chip1ET6525SA
Power (W)450.0
Superbe ampli
Enfin les sensations que je recherchais depuis un moment pour le Homecinéma. L'ampli révèle des performances que je ne soupçonnais pas de la part de mon Processeur Marantz 8805A : les impacts surtout avec beaucoup de micro détails et nuances et le tout avec une grande finesse et placement des objets dans l'espace.
En Hifi ? Pour l'instant le passe par mon Marantz pour écouter Qobuz via Audirvana. Je vais évoluer avec un DAC dédié mais pour le moment c'est déjà très bien. Impressionnant cette foultitude de détails à bas volume et un silence parfait ! Sans oublier cette maitrise totale des basses ! Attention du coup à la source car c'est très transparent et "sec ?" mais j'atteins là surement les performances du DAC du Marantz en mode Hifi qui n'est pas sa vocation première.
En comparaison, j'avais acheté cet ampli 4 canaux pour mes surround, centrale et une seule surround Back (mode 6.1) mais finalement je l'utilise sur mes colonnes principales au lieu des surrounds à la place de mon Denon PMA 110. Ces colonnes sont des Dynaudio Evoke50 pilotées sans problème. J'ai connecté une colonne par alimentation du HPA comme si j'avais 2 blocs séparés.
Pour finir sur Audiophonics, beaucoup de choses on été dites et je confirme leur sens du service client et les échanges quasi instantanés avec leur service support. Merci !
This review has been posted for AUDIOPHONICS HPA-Q450ET Power Amplifier Class D Four Channel Purifi 1ET6525SA 4x450W 4 Ohm
The Audiophonics HPA-Q450ET power amplifier is based on a Class D architecture, using four Purifi 1ET6525SA amplifier modules, two Hypex...
