AUDIOPHONICS HPA-T450ET Power Amplifier 3 Channels Purifi 1ET6525SA
The Audiophonics HPA-T450ET power amplifier is based on a Class D architecture, using three Purifi 1ET6525SA amplification modules, a Hypex SMPS1200A400 power supply and an Audiophonics custom buffer stage, enabling the amplifier to deliver incredible performance. Like all Audiophonics Workshop products, this HPA-T450ET is meticulously designed and assembled by hand in our workshop in France.
By buying this product you get 199 loyalty points
Reference : 20209
1 990,00 €tax incl.
1 658,33 € tax excl.
Shipping date: 24-04-2025.
Audiophonics Workshop amplifiers range
This appliance is supplied as standard with a 230V AC supply voltage. If you require a 110V input voltage, please select this using the switch on the underside of the device before connecting it to the mains.
Audiophonics HPA-T450ET Power Amplifier Class D 3 Channels Purifi 1ET6525SA 3x450W 4 Ohm
Audiophonics HPA-T450ET: Front view
The Audiophonics HPA-T450ET is a powerful, robust and high-performance amplification solution. It is capable of powering demanding HiFi audio systems, while revealing sound reproduction of incomparable finesse, rich in detail and perfectly transparent. There's no compromise here between power and sonic precision. The on-board Purifi modules feature a particularly rigorous design, delivering exceptional measured performance.
With its three channels, the HPA-T450ET is ideal for integrating into a home cinema system, providing power to both the front speakers and a centre channel or passive subwoofer.
All elements and components are integrated into a solid, sturdy aluminum housing with a modern, streamlined design. This chassis also features openings and side heat sinks for efficient heat dissipation. What's more, its design effectively limits the impact of interference on the audio signal.
Audiophonics HPA-T450ET: Key features
Audiophonics HPA-T450ET: Purifi 1ET6525SA amplification modules
Each channel of the Audiophonics HPA-T450ET amplifier circuit is equipped with its own Purifi 1ET6525SA amplifier module. These use high-performance Class D architecture, with available power of 3x450W into 4Ω or 3x230W into 8Ω (at 1% THD) and high efficiency of over 94%. They also guarantee a very low level of THD, intermodulation distortion and noise, for a rich, precise and perfectly transparent sound reproduction, perfectly respecting the original audio signal to reproduce your music with unequalled fidelity and without coloration. It also guarantees a wide, realistic sound image, for perfect immersion.
Purifi's ongoing research into non-linear control theory has led to the development of the first mathematically accurate large-signal model for self-oscillating amplifier controllers. This breakthrough enables the feedback circuit to be fully optimized, resulting in a significant performance improvement over other designs. What's more, these Purifi 1ET6525SA modules feature a complete protection system for enhanced durability.
Audiophonics HPA-T450ET: Hypex SMPS1200A400 power supply module
The power supply stage of the Audiophonics HPA-T450ET uses an ultra-high-efficiency Hypex SMPS1200A400 switch-mode power supply module, capable of developing 1200W of power. This has been specifically designed and developed by Hypex to provide the voltage required for optimum operation of the amplifier modules.
This high-quality, low-noise power supply perfectly meets the energy requirements of the Purifi 1ET6525SA amplifier modules. What's more, the amplifier modules themselves have an excellent ability to reject power supply noise. As a result, the HPA-T450ET is highly insensitive to power grid imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics HPA-T450ET: Proprietary buffer interface board
The three amplifier modules are driven in phase opposition to cancel the Power Supply Pumping effect. This makes for greater power supply stability, alternately distributing current calls on each rail and thus increasing its capacity. A voltage regulation stage is used to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules. One Audiophonics OPA1656 OPA is used per channel. These are very low-distortion OPAs, offering the highest transparency with very low THD. They are mounted on a socket so they can be replaced if necessary.
In addition, a gain control is located on the underside of the unit to suit all applications. Four gain settings are available: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics HPA-T450ET: Balanced & single-ended connectors
Designed for easy integration, the Audiophonics HPA-T450ET features both balanced inputs on XLR connectors and single-ended inputs on RCA connectors. Bipolar selectors on the rear of the unit allow easy selection of the active input, even enabling independent channel control. On the output side, insulated Audiophonics terminal blocks (developed in partnership with AEC Connectors) with 24k gold-plated contacts ensure an excellent connection between amplifier and loudspeaker. A 5-12V trigger module with input and output allows the amplifier to be integrated into an automatic on/off chain for your entire audio system.
With three channels, the HPA-T450ET can be used in both HiFi and home cinema systems. In the latter case, it is perfectly capable of powering two front speakers and a centre speaker or passive subwoofer.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
Audiophonics HPA-T450ET: Amplifier diagram
1ON/OFF button
2Power input
35-12V trigger input
4Speaker output
5Speaker output
6Speaker output
75-12V trigger output
8XLR balanced input
9Input selector
10RCA single-ended input
11XLR balanced input
12Input selector
13RCA single-ended input
14XLR balanced input
15Input selector
16RCA single-ended input
THD vs Frequency @ 4Ω
Audiophonics HPA-S450ET: THD vs. frequency curve
THD+N vs Power @ 1kHz
Audiophonics HPA-S450ET: THD+N vs Power curve
Frequency response @ 2.83V
Audiophonics HPA-S450ET: Frequency response curve
Product typePower amplifier
Amplification modules3x Purifi 1ET6525SA
Number of channels3 channels
Amplification typeClass D
Output power3x230W @ 8Ω, 1% THD
3x450W @ 4Ω, 1% THD
3x510W @ 2Ω, 1% THD
Efficiency> 94%
Inputs3x Balanced XLR
3x Single-ended RCA
OutputsSpeaker terminals
Trigger5-12V in/out on mono Jack 3.5mm
THD+N0.00035% @ 1W, 1kHz
0.0001% @ 10W, 1kHz
0.00005% @ 100W, 1kHz
0.00035% @ 1W, 20Hz-20kHz
0.00029% @ 10W, 20Hz-20kHz
0.0001% @ 100W, 20Hz-20kHz
IMD (CCIF)0.0000003% @ 1W, 18.5kHz+19.5kHz
0.0000006% @ 10W, 18.5kHz+19.5kHz
0.0000005% @ 100W, 18.5kHz+19.5kHz
IMD (DIM)0.002% @ 1W, DIM30
0.002% @ 10W, DIM30
0.009% @ 100W, DIM30
Idle noise (ICN)6.6µV @ A-wt
Dynamic range137dB @ A-wt
SNR137dB @ A-wt
Frequency response±0.01dB @ 8Ω, 20Hz-20kHz
±0.01dB @ 4Ω, 20Hz-20kHz
±0.01dB @ 2Ω, 20Hz-20kHz
Input impedanceRCA : 10kΩ
XLR : 20kΩ
Output impedance0.03mΩ @ 1kHz, 1A
< 0.35mΩ @ 20Hz-20kHz, 1A
XLR Gain / Input sensitivity for max power @ 1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
RCA Gain / Input sensitivity for max power @ 1% THD12.5dB / 5.03Vrms
20dB / 2.12Vrms
25dB / 1.24Vrms
29dB / 0.75Vrms
Supply voltage110-230V AC (switchable, selection switch under the device)
Housing materialAluminum
Total dimensions (WxDxH)435 x 355 x 73mm
Weight6kg
Package1x Audiophonics HPA-T450ET
1x Power cord
InputXLR
OutputSpeaker terminal
Channel3
Amplifier chip1ET6525SA
Power (W)450.0
2 reviews
Excellent amplifier
Excellent amplifier with just a few minor imperfections:
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sond system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays
- ideally, remote switching of the gain (e.g. depending on the selection of the XLR or RCA input) would be fantastic (but possibly too complicated)
This review has been posted for AUDIOPHONICS HPA-T450ET Power Amplifier Class D 3 Channels Purifi 1ET6525SA 3x450W 4 Ohm
Oui, la hi-fi et le home cinéma dans le même système c'est possible!
Ma combinaison Marantz Cinema 50 et Dynaudio Emit en 3.0 ne me donnait pas satisfaction: passable en home-cinéma et décevante en stéréo pour la musique. L'ajout de cet ampli, certes pas donné mais bien moins cher que les réalisation de marques prestigieuses qui utilisent les mêmes modules, a tout changé:
- matériel très solidement construit et connecteurs de haute qualité: ça fait haut de gamme
- ne chauffe pas du tout (mais alors pas du tout)
- mon Marantz ne chauffe plus non plus car il ne sert que de pré-ampli
- son home-cinéma beaucoup plus ample et précis, voix et dialogues très clairs, effets de basses amples
- mais surtout, retour dans le monde de la hi-fi pour la musique: clarté, transparence, contrôle des basses, absence de fatigue, aigus cristallins mais élégants, scène stéréo en 3D, positionnement des instruments et des voix "dans la pièce". J'étais déjà passé à la classe D dans ma chaine musicale Nuprime, ici on est au moins à ce niveau voire plus.
Deux minuscules regrets:
- un tout petit parasite à l'allumage
- pas de version "silver" du coffret
Merci à Audiophonics (et Purifi) pour cette belle réalisation.
The Audiophonics HPA-T450ET power amplifier is based on a Class D architecture, using three Purifi 1ET6525SA amplification modules, a Hypex...
