AUDIOPHONICS LPA-S400ET Power Amplifier Class D Purifi 1ET400A 2x400W 4 Ohm
We are proud to offer you the Audiophonics LPA-S400ET, a Class D stereo power amplifier based on two Purifi 1ET400A modules. This ready-built and ready-to-use version is for audiophiles who want to equip themselves with a foolproof amplification solution, with a considerable power reserve as well as a perfect linearity. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with simply outstanding measured performance.
By buying this product you get 119 loyalty points
Reference : 14557
1 190,00 €tax incl.
991,67 € tax excl.
Shipping date: 07-05-2025.
Audiophonics Workshop amplifiers range
This product has been replaced by the Audiophonics LPA-S450ET.
This unit is supplied with a 230V AC power supply as standard. If you require a 110V input voltage, please select this using the switch on the underside of the unit before connecting it to the mains.
Class D Stereo Amplifier Purifi 1ET400A 2x400W 4 Ohm
Audiophonics LPA-S400ET Amplificateur de puissance PURIFI 2x400W 4 Ohm
We are proud to offer you the Audiophonics LPA-S400ET, a Class D stereo power amplifier based on two Purifi 1ET400A modules. Similar electronically to the HPA-S400ET, this version is mounted in a more compact box making it easier to use in an environment where space is limited, its architecture also limits the length of the internal connections.
This ready-built and ready-to-use version is for audiophiles who want to equip themselves with a foolproof amplification solution, with a considerable power reserve as well as a perfect definition. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with simply outstanding measured performance.
The package offers a high level of sound reproduction suitable for use with demanding loudspeakers, for large listening rooms or for studio applications requiring a large headroom without compromising on the accuracy and richness of the audio message.
All the components are integrated in a 100% Aluminium housing that is sober, robust, design and compact. This one has openings in order to facilitate heat dissipation. Its design also allows it to limit the impact of interference on the signal.
Two PURIFI 1ET400A modules
  • Each channel of the amplifier circuit uses its own PURIFI 1ET400A module. These high-performance Class D amplifier circuits each offer a very comfortable 200W at 8 Ohm while benefiting from the high efficiency of Class D amplifiers.
  • The 1ET400A modules embody a high gain loop greater than 75dB over the entire frequency band, providing high performance over the entire spectrum, surpassing any amplifier of any class.
  • Highly efficient in terms of Intermodulation Distortion Mode (IMD), these modules enable the LPA-S400ET to deliver a stereophonic image with high accuracy across the entire spectrum, providing even greater clarity during even the most complex musical works.
  • Harmonic distortion (THD) is kept extremely low at all power levels. This results in a lack of sound signature and the ability to reproduce all types of music without coloration.
  • The output noise is negligible, which allows deep silences and promotes the appearance of detail when listening at low volume levels.
  • The circuit benefits from a high rejection level (PSRR) that minimizes the impact of the power supply on audio performance.
  • The load-independent frequency response makes it possible to enjoy all the qualities of this amplification technology, even with the most difficult to drive speakers.
  • Low power consumption at rest and electromagnetic radiation (EMI). The high gain loop significantly relieves the workload of MOSFETs and allows them to operate under optimal operating conditions, reducing losses and EMI emissions.
  • The LPA-S400ET has its amplifier modules connected with a specially developed interface card for optimal integration.
Hypex Power Supply Module SMPS1200A400
The SMPS1200 switched-mode power supply is a very high efficiency model capable of developing a rated power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by Hypex to provide the 2x64V voltage required to operate the most demanding amplifier modules.
This low-noise quality power supply meets the power requirements of the amplifier modules in every respect. In addition, the amplifier modules themselves have an excellent ability to reject supply noise. This makes the LPA-S400ET extremely insensitive to mains imperfections and voltage/current fluctuations that can cause interference noise.
Audiophonics interface board
The 2 modules are driven in phase opposition, to cancel the "Power-Supply Pumping" effect. This allows a greater stability of the power supply, distributing alternately on each rail the calls of current and thus increasing its capacities.
We have opted for a 2-level voltage regulation, to optimise the power supply to the OPAs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 per channel is used. These are very low distortion OPAs offering the highest transparency with a very low THD. They are mounted on a DIP8 socket, allowing their replacement if needed.
To suit all applications, we have opted for 5 gain settings, switchable via jumper on the underside of the unit :
  • Gain of +7.2dB, i.e. a total of 20dB - Maximum power reached with a 4.19V RMS signal.
  • Gain of +12.5dB, i.e. a total of 26dB (default) - Maximum power reached with a signal of 2.07V RMS.
  • Total gain of 32dB - Maximum power reached with a signal of 1.05Vrms
  • Total gain of 34dB - Maximum power reached with a signal of 0.83Vrms
  • Bypass (buffer deactivated): In this case, the signal passes directly from the inputs to the modules, allowing the lowest possible gain of 12.5dB. This mode can be interesting when using a powerful preamplifier, capable of driving a load of 2 to 4K Ohm and reaching a voltage of 10V RMS.
Connectivity
Designed for easy integration, the LPA-S400ET has a balanced (XLR) and unbalanced (RCA) stereo input. Bipolar switches allow easy switching between input sources and even allow independent channel control.
On the output side, BP-207 carbon / 24k Ø5.5mm gold / carbon insulated terminals provide an excellent connection to the loudspeakers.
THD+N
Frequency response
THD vs Freq
Product typePower amplifier
Power227W @ 8Ω, 1%THD
425W @ 4Ω, 1%THD
450W @ 2Ω, 1%THD
THD+N0.0007% @ PO=1W, f=1kHz
0.00026% @ PO=10W, f=1kHz
0.00015% @ PO=100W, f=1kHz
0.0007% @ PO=1W, f=20Hz-20kHz
0.00029% @ PO=10W, f=20Hz-20kHz
0.00017% @ PO=100W, f=20Hz-20kHz
IMD (CCIF)0.00025% @ PO=1W, f=18kHz+19kHz
0.00022% @ PO=10W, f=18kHz+19kHz
0.00027% @ PO=100W, f=18kHz+19kHz
IMD (DIM)0.002% @ PO=1W, DIM30
0.002% @ PO=10W, DIM30
0.002% @ PO=100W, DIM30
Quiescent noise11.5µV (A-Weighted)
Dynamic range131dB @ 4Ω (A-Weighted)
SNR131dB @ 4Ω (A-Weighted)
Frequency response20Hz - 20kHz ±0.01dB @ RL=8Ω
20Hz - 20kHz ±0.01dB @ RL=4Ω
20Hz - 20kHz ±0.01dB @ RL=2Ω
Output impedanceIout = 1A @ 0.07mΩ, 1kHz
Iout = 1A @ < 0.65mΩ, 20Hz-20kHz
Input impedanceRCA : 47kΩ / XLR : 100kΩ
Bypass : 2.2kΩ / 4.4kΩ
Power supply110-230V AC (default: 230V)
Dimensions (without connectors)19 x 35.9 x 7.8cm
Weight3.17kg
Housing materialAluminium
Power cableIncluded
Input
  • RCA
  • XLR
Output
  • Speaker terminal
Color
  • Black
Channel
  • 2 (Stereo)
Class
  • Class D / T
Amplifier chip
  • Purifi 1ET400A
Power (W)
  • 400.0
Remote Control
  • No
58 reviews
superbe
après avoir eu depuis 4 ans le MPA-S250NC qui me convenez très bien est a comparer à d'autres ampli de classe A il n'avait pas a rougir . ce à quoi j'ai jeté mon dévolu sur le purifi LPA-S400ET en comparaison du MPA S250C UN GAP significatif de maitrise de la musique d'une justice insoupçonnée de micro Details très aéré qui en fait en parti un produit exceptionnel merci a vous pour tous les conseils avérés des produits audiophonics
This review has been posted for AUDIOPHONICS LPA-S400ET Power Amplifier Class D Purifi 1ET400A 2x400W 4 Ohm
rodage
Comme déjà signalé, cet ampli nécessite un rodage sérieux (plusieurs dizaines d'heures) avant d'en tirer la quintessence. Ne pas se fier aux premières impressions qui peuvent être un peu décevantes (bien à tort). Magnifique ensuite.
Thanks to the Audiophonics team for quickly repairing my amplifier. Very responsive service. The quality of the device is unsurpassed for its price.
More air compared to N-Core 502. To obtain a good sound, it requires at least 10 hours of heating. Excellent build quality.
Jean O.
J’ai acheté cet ampli Purifi en remplacement d’un ampli Project Amp Box DS2. Ce dernier est équipé de modules Hypex UCD 180. Bien que fonctionnant tous deux en classe D et ayant la même origine, des différences audibles existent. Le Purifi a plus d’assise dans les basses et est moins montant dans les aigus que le project. Il est également plus transparent (microdétails) et plus naturel. Bref très bonne impression. Merci audiophonics.
Attention, le boitier est étroit mais profond. J’ai du utiliser un cable d’alimentation et des renvois RCA coudés pour qu’il rentre dans le meuble.
We are proud to offer you the Audiophonics LPA-S400ET, a Class D stereo power amplifier based on two Purifi 1ET400A modules. This ready-built and...
