AUDIOPHONICS LPA-S450ET Power Amplifier Stereo Purifi 1ET6525SA
We're proud to present the Audiophonics LPA-S450ET, a Class D stereo power amplifier based on two Purifi 1ET6525SA modules. Electronically similar to the HPA-S450ET, this version is housed in a more compact case, making it easier to use in environments where space is at a premium, and its architecture also limits the length of internal connections.
By buying this product you get 129 loyalty points
Reference : 20206
1 290,00 €tax incl.
1 075,00 € tax excl.
Shipping date: 24-04-2025.
Audiophonics Workshop amplifiers range
This unit is supplied with a 230V AC power supply as standard. If you require a 110V input voltage, please select this using the switch on the underside of the unit before connecting it to the mains.
Audiophonics LPA-S450ET Class D Stereo Amplifier PURIFI 1ET6525SA 2x450W 4 Ohm
Audiophonics LPA-S450ET: 3/4 view
This ready-to-install, ready-to-use model is aimed at audiophiles looking for a foolproof amplification solution, with considerable power reserves and impeccable definition. PURIFI modules are among the most rigorous Class D amplification solutions on the market, with measured performance that is simply outstanding.
The result is a high level of sound reproduction, suitable for use with demanding speakers, large listening rooms or studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All components are housed in a sober, robust and compact aluminum case. It features openings to facilitate heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics LPA-S450ET : PURIFI 1ET6525SA module
Audiophonics LPA-S450ET: Two PURIFI 1ET6525SA modules
  • Each channel of the amplifier circuit uses its own PURIFI 1ET6525SA module. These high-performance Class D amplifier circuits each deliver a very comfortable output power of 450W at 4Ω or 230W at 8 Ohm, while benefiting from the high efficiency of Class D amplifiers.
  • The 1ET6525SA modules feature a high-gain loop in excess of 85dB over the entire frequency band, providing high performance across the entire spectrum, surpassing any amplifier of any class.
  • Highly effective in terms of intermodulation distortion (IMD), these modules enable the LPA-S450ET to deliver a stereophonic image of formidable precision across the entire spectrum, for redoubled clarity, even during the most complex musical works.
  • Harmonic distortion (THD) is kept extremely low at all power levels. This translates into an absence of sound signature and the ability to reproduce all types of music without coloration.
  • Output noise is negligible, allowing deep silences and favoring the appearance of detail when listening at low volume.
  • The circuit benefits from a high level of rejection (PSRR) that minimizes the impact of the power supply on audio performance.
  • The load-independent frequency response makes it possible to enjoy all the qualities of this amplification technology, even with the most difficult-to-drive speakers.
  • Low quiescent power consumption and electromagnetic radiation (EMI). The high-gain loop considerably relieves the workload on the MOSFETs, enabling them to operate under optimum conditions, reducing losses and EMI emissions.
  • The LPA-S450ET's amplifier modules are linked by a specially developed interface board for optimum integration.
Audiophonics LPA-S450ET: Hypex SMPS1200A400 power supply module
The SMPS1200 switched-mode power supply is an ultra-high-efficiency model capable of developing a rated power of 1200 Watts in an extremely compact design. It has been specifically designed and developed by Hypex to supply the 2x64V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the modules themselves have an excellent ability to reject power supply noise. As a result, the LPA-S450ET is extremely insensitive to mains imperfections and voltage/current variations that can cause parasitic noise.
Audiophonics LPA-S450ET : Hypex SMPS1200A400 power supply module
Audiophonics LPA-S450ET: Audiophonics interface board
The 2 modules are controlled in phase opposition, to cancel the “Power-Supply Pumping” effect. This makes for greater power supply stability, alternately distributing current calls on each rail, thus increasing its capacity.
A voltage regulation stage is used to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 OPA is used per channel. These are very low-distortion OPAs offering the highest transparency with very low THD. They are mounted on a DIP8 socket, allowing them to be replaced if necessary.
To suit all uses, we have opted for 4 gain settings, selectable via jumper on the underside of the unit: 12.5dB, 20dB (default), 25dB and 29dB.
Audiophonics LPA-S450ET: Connectors
Designed for easy integration, the LPA-S450ET features both single-ended (RCA) and balanced (XLR) stereo inputs. Bipolar selectors make it easy to change input sources, and even allow independent control of channels.
At the output, BP-207 carbon / 24k gold insulated terminal blocks Ø5.5mm ensure an excellent connection with the speakers.
Audiophonics LPA-S450ET : Rear view
Audiophonics LPA-S450ET : THD vs Freq
Audiophonics LPA-S450ET : THD+N
Audiophonics LPA-S450ET : Frequency response
Test du AUDIOPHONICS LPA-S450ET par QOBUZ
If we had to keep just one power amplifier, it might just be this Audiophonics LPA-S450ET. It isn’t an entry-level product. But it’s equally far from the high end, and yet, it offers impeccable sound reproduction capabilities, both on paper and in practice. The power is there, but it takes a backseat to the music, which is reproduced with all its finesse, complexity, and presence. The LPA-S450ET will be a solid foundation to any high-quality Hi-Fi system.
 Logo Quobuz
Product typePower amplifier
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs2x Speaker terminals
Power2x230W @ 8Ω, 1%THD
2x450W @ 4Ω, 1%THD
2x510W @ 2Ω, 1%THD
Total harmonique distorsion (THD+N)0.00035% @ PO=1W, f=1kHz
0.0001% @ PO=10W, f=1kHz
0.00005% @ PO=100W, f=1kHz
0.00035% @ PO=1W, f=20Hz-20kHz
0.00029% @ PO=10W, f=20Hz-20kHz
0.0001% @ PO=100W, f=20Hz-20kHz
IMD (CCIF)0.0000003% @ PO=1W, f=18.5kHz+19.5kHz
0.0000006% @ PO=10W, f=18.5kHz+19.5kHz
0.0000005 % @ PO=100W, f=18.5kHz+19.5kHz
IMD (DIM)0.002% @ PO=1W, DIM30
0.002% @ PO=10W, DIM30
0.009% @ PO=100W, DIM30
Idle Noise6.6µV (A-Weighted)
Dynamic range137dB @ 4Ω (A-Weighted)
SNR137dB @ 4Ω (A-Weighted)
Frequency response20Hz - 20kHz ±0.01dB @ RL=8Ω
20Hz - 20kHz ±0.01dB @ RL=4Ω
20Hz - 20kHz ±0.01dB @ RL=2Ω
Output impedanceIout = 1A @ 0.03mΩ, 1kHz
Iout = 1A @ < 0.35mΩ, 20Hz-20kHz
Input impedanceRCA : 10kΩ
XLR : 20kΩ
XLR Input gain / sensitivity for max power at 1% THD12.5dB / 10.06Vrms
20dB / 4.24Vrms
25dB / 2.39Vrms
29dB / 1.51Vrms
RCA Input gain / sensitivity for max power at 1% THD12.5dB / 5.03Vrms
20dB / 2.12Vrms
25dB / 1.24Vrms
29dB / 0.75Vrms
Power supply110-230V AC (230V par défaut)
Total dimensions (WxDxH)191 x 386 x 82mm
Weight3.17kg
Housing materialAluminum
Package1x Audiophonics LPA-S450ET
1x Power cord
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chip1ET6525SA
Power (W)450.0
7 reviews
Ampli purifi
Cela fait seulement 2 jours que j ai reçu mon ampli purifi et donc tjrs en rodage.
La claque, il exploser en tout point mon ancien ampli pourtant 3 fois plus cher...
Je n' ose Imaginer dans quelques heures ce que cela va me donner...
Tout y est, à la bonne place, avec une précision extraordinaire.
Tout est sublimé.
Je suis super content de mon achat et certainement le dernier ampli que j achète.
Merci audiophonics pour donner la possibilité d avoir une amplification aussi bonne, à si peu cher en comparaison.
This review has been posted for AUDIOPHONICS LPA-S450ET Class D Stereo Amplifier PURIFI 1ET6525SA 2x450W 4 Ohm
L'ampli idéal
J'ai eu pas mal d'ampli et souvent pas 100% satisfait mais là j'ai été convaincu dès les premières écoutes. Le son est fantastique tout simplement.
Autant j'ai été déçu par un ampli comme le topping LA90, qui a de bonnes mesures mais est pouratnt très mauvais à l'écoute.
Je n'ai pas encore le comparer à mon ampli de référence mais je suis super content. J'ai l'impression qu'il est diffcilie de trouver mieux à ce prix.
Exceptionnel
Je viens enfin de brancher mon ampli de puissance. Après avoir attendu le temps de chauffe nécessaire, c'est une révélation. J'ai l'impression d'avoir de nouvelles enceintes. Je découvre le potentiel de mes Triangle Esprit Antal EZ, grosse montée au niveau des basses, impressionnant, un caisson de basse s'avère inutile. Mon ampli Yamaha RN1000A se concentre sur les médium haut et sur les aigus.
Pour info, suite au conseil donné ( merci encore aux équipes d’Audiophonics, technique et réactif) j'ai réglé mes curseurs sur un gain de + 29dB pour avoir le même niveau de volume.
Excellent ampli !!!
Reçu 3 jours après la commande, et testé tout suite après avec un streamer/dac/preampli Yamaha wxc-50 et mes chères enceintes Triangle Lyrr 222 (93dB de rendement et 8 Ohms). Le réglage de gain à 20dB est correct pour mes besoins. Très transparent, il fait ressortir beaucoup de détails dans tout la gamme spectrale. L'écoute n'est pas de tout fatigante il convient bien au classique, jazz, pop, rock. Bref, le LPA-S450ET tient tous les promesses qui apparaissent dans le descriptif d'Audiophonics. Rien à ajouter de plus. Je recommande cet ampli.
Grand merci à David Aubert d'Audiophonics pour m'avoir aiguillé sur cet ampli.
Exceptional sound quality
I also have an "LPA-S600NCX" stereo power amplifier and wanted to compare the two concepts. I really struggle to determine if there is a repeatable difference between the two amplifiers. On certain tracks I feel that the Purifi is slightly more relaxed & natural and on others feel that the Hypex is a bit punchier in the bass. However, I am not confident that these subjective observations are repeatable. Both amplifiers are neutral (in a positive way), musical & silent. The one noticeable / repeatable difference is that the Purifi is cooler to the touch. Save a bit of money and buy the Hypex ncx? You cannot go wrong with either - both are exceptional amplifiers!
 (4)
We're proud to present the Audiophonics LPA-S450ET, a Class D stereo power amplifier based on two Purifi 1ET6525SA modules. Electronically...
