AUDIOPHONICS LPA-S600NCX Power Amplifier Class D NCore NCx500 2x600W 4 Ohm
We are proud to present the Audiophonics LPA-S600NCX, a Class D stereo power amplifier based on two NCore NCx500 modules. This ready-to-use version is aimed at audiophiles who want a foolproof amplification solution, with a considerable power reserve and impeccable linearity.
By buying this product you get 109 loyalty points
Reference : 17966
1 090,00 €tax incl.
908,33 € tax excl.
Shipping date: 23-09-2026.
Audiophonics Workshop amplifiers range
This unit is supplied with a 230V AC power supply as standard. If you require a 110V input voltage, please select this using the switch on the underside of the unit before connecting it to the mains.
Power amplifier NCore NCx500 2x600W 4 Ohm
Audiophonics LPA-S400ET Amplificateur de puissance PURIFI 2x400W 4 Ohm
We are proud to present the Audiophonics LPA-S600NCX, a Class D stereo power amplifier based on two NCore NCx500 modules. Electronically similar to the HPA-S600NCX, this version is housed in a more compact enclosure, making it easier to use in environments where space is at a premium. Its architecture also limits the length of the internal connections.
This ready-to-use, pre-assembled model is aimed at audiophiles looking for a foolproof amplification solution with a considerable power reserve and impeccable definition. NCore modules are among the most rigorous Class D amplification solutions on the market, with simply exceptional measured performance.
The whole package delivers a high level of sound reproduction, ideal for use with demanding loudspeakers, in large listening rooms or in studio applications requiring considerable headroom without compromising on the precision and richness of the audio message.
All the components are housed in a sober, robust, stylish and compact 100% aluminium enclosure. The enclosure has apertures to promote heat dissipation. Its design also limits the impact of interference on the signal.
Audiophonics LPA-S600NCX Amplificateur de puissance 2x600W 4 Ohm
Two NCx500 OEM mono modules
Each channel of the Audiophonics LPA-S600NCX features its own Hypex NCore NCx500 amplification circuit with high efficiency and low output impedance, distortion and noise. This new module has greatly improved performance in terms of distortion and output impedance. Each amplifier module is capable of delivering 700W of power at 1% THD. The integrated 1200W HYPEX power supply enables them to simultaneously deliver 600W at 0.01% THD into 4Ω.
Particular care has been taken with the internal wiring and assembly of the amplifier, using large-section power supply wires, Canare input signal cables and PTFE-insulated speaker cables.
Hypex SMPS1200A700 Power supply module
The SMPS1200 switching power supply is a very high efficiency model capable of developing a rated power of 1200 Watts in an extremely small footprint. It has been specifically designed and developed by Hypex to supply the 2x85V voltage required to operate the most demanding amplifier modules.
This high-quality, low-noise power supply meets the power requirements of the amplifier modules in every respect. What's more, the modules themselves have an excellent ability to reject power supply noise. As a result, the LPA-S600NCX is extremely insensitive to imperfections in the electrical network and to voltage/current variations that can cause parasitic noise.
Audiophonics interface board
The 2 modules are controlled in phase opposition, to cancel the "Power-Supply Pumping" effect. This makes the power supply more stable, distributing the current draw alternately on each rail, thereby increasing its capacity.
We opted for 2-level voltage regulation, to optimise the power supply to the AOPs and the auxiliary voltage supplied to the modules.
One Audiophonics OPA1656 PDU is used per channel. These are very low distortion PDUs offering the greatest transparency with very low THD. They are mounted on a DIP8 socket, allowing them to be replaced if necessary.
To suit all applications, we have opted for 4 gain settings, switchable via switch on the underside of the unit :
  • Total gain of 11.5dB - Maximum power reached with a 13.03V RMS signal.
  • Total gain of 19dB (default) - Maximum power reached with a 5.5V RMS signal.
  • Total gain of 24dB - Maximum power reached with a 3.09Vrms signal
  • Total gain of 28dB - Maximum power reached with a 1.95Vrms signal
Connectivity
Designed for easy integration, the LPA-S600NCX has both balanced (XLR) and unbalanced (RCA) stereo inputs. Bipolar selectors make it easy to change input sources and even allow independent control of channels.
On the output side, BP-207 carbon / 24k gold insulated terminals (Ø5.5mm) provide an excellent connection to loudspeakers.
Technical specifications
Type of productPower amplifier
Type of amplificationClass D
Amplifier modules2* Hypex NCore NCx500
Channels2 (Stereo)
Inputs1x Stereo RCA
1x Balanced XLR 3-pin
Other connectorsTrigger 5-12V
TechnologyNcoreX
Power2x500W under 2Ω @ 1kHz THD=0.01%
2x600W under 4Ω @ 1kHz THD=0.01%
2x300W under 8Ω @ 1kHz THD=0.01%
THD+N @ 20Hz-20kHz, 4ΩTyp : 0.0006%
Max : 0.001%
SNR137dB
Output noise7µV
Frequency response0Hz - 70kHz @ +0/-3dB
Gain (selectable)Bypass : 11.5dB
19dB
25dB
31dB
33dB
Efficiency (full power)92%
Dumping factor1600 @ 1khz
2000 @ full band
Supply voltage110-230VAC (default: 230V)
Max. power consumption1300W
ChassisSand-blasted aluminium
Total dimensions (WxDxH)191 x 386 x 82mm
Net weight3.17kg
Package1x Audiophonics LPA-S600NCX
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)600.0
12 reviews
Pleasantly surprised.
Purchased this to compliment my Canton Vento 896 DCs for front L/R operations - these were previously driven solely by my Denon X4400H. The amp upgrade was intend d to provide more headroom (50/50 music/movies). I wasn’t expecting a massive difference in SQ, but I was quite mistaken - the bass has noticeably more ‘slam’ and drives the woofers with much more perceived precision and speed. Midrange, particularly vocals, are much more present. All in all, a marked improvement. Great work by the team at Audiophonics - so far, I can highly recommend!
This review has been posted for AUDIOPHONICS LPA-S600NCX Power Amplifier Class D NCore NCx500 2x600W 4 Ohm
Très très bon ampli !!!
J'ai fait l'acquisition de 4 amplis LPA-S600NCX pour alimenter une installation a très haut rendement en 2 x 4 voies.
C'est un pur bonheur, ca marche du grave à l'aigue, avec finesse et force sans aucune agressivité. Pas un pet de souffle dans mes compressions. Est-ce l'ampli ultime ? Je ne sais pas, mais en tout cas, j'ai fini de chercher.
Super
Połączyłem bezpośrednio z NODE ICONE przez XLR . Dodatkowo uziemiłem przewodem RCA gdyż słyszalne były niechciane dźwięki. ( zalecenie na stronie Bluesound) Działa idealnie. Triger połączyłem zwykłym kabelkiem stereo 3.5. Polecam . Wcześniej testowałem też z DMP A6 ME gen 2 . Na moje ucho było za ostro :).
Fast shipping.
Robust and built by Audiophonics at an amazing price.
The sound is excellent. Ranked 5th out of many numerous amplifiers in the ASR ranking.
After a few days, the unit sounds even better.
Unfortunately, this amplifier requires 13-14 volts of input voltage to deliver its full power.
Most preamplifiers deliver up to 2-2.5 volts.
It is possible to adjust the gain on the bottom of the unit using the preamplifier itself.
Unfortunately, this somewhat degrades the excellent technical values ​​(Sinad from 137 dB to 128, etc.).
These are still excellent values, and I don't hear any sonic differences on my Nuvero 140.
Audiophonics specifies the following gain values:
Bypass: 11.5 dB
19 dB
25 dB
31 dB
33 dB
The following values ​​can be set on the device:
11.5 dB
19 dB
24 dB
28 dB
I love this amplifier. I've certainly owned over 10 select and well-tested amplifiers before.
The LPA-S600NCX is my favorite.
Plenty of stage, plenty of detail, and decent dynamics.
Mr.
Haves used this amplifier for 8 month now and upgraded today from LM4562 (this was the stock op amp at that time) to OPA1656 in the buffer stage. The amplifier got even better than before, especially voices has more natural sound and body. It’s a fantastic amplifier, it delivers plenty of clean power with 100% control and dynamics.
We are proud to present the Audiophonics LPA-S600NCX, a Class D stereo power amplifier based on two NCore NCx500 modules. This ready-to-use version...
