AUDIOPHONICS TDA8954 High fidelity Amplifier Class D 2x 90W / 8 Ohm Silver
Reference : 11080
299,00 €tax incl.
249,17 € tax excl.
This digital power amplifier assembled in our workshops incorporates an amplification module TDA8954.
Especially effective, it is the most compact powered amplifier in its class with an output power of 2x170W under 4 Ohm or 2x90W under 8 Ohm.
All these powers are measured at <1% THD.
The input signal may be symmetrical or asymmetrical. Here we offer the asymmetrical version (RCA).
The amplifier has overvoltage, overcurrent and short-circuit protection.
The gain of the amplifier is 30dB.
The power transistors and rectifying diodes of the power supply section do not require a heat sink for operation due to the high efficiency of the power supply.
Its elegant aluminum case (with Silver front) is above all robust and its discreet design will allow it to find its place with ease in all the configurations of your Hi-Fi systems.
Characteristics :
  • Amplifier TDA8954
  • Power: 2x170W at 4 Ohms or 2x90W at 8 Ohms
  • "Ploc" anti-ignition system
  • Stereo RCA Input
  • RCA sockets ELECAUDIO ER-103 insulated PTFE Gold plated
  • Hp terminal outputs accepting forks and banana plugs
  • BP-206 Insulated Gold Plated Terminals
  • Light switch ELECAUDIO bi-stable Aluminum switch
  • Wire Wire Insulated Copper FEP 1.6mm²
  • Power Supply IEC ELECAUDIO ES-3G Gold plated 24k
  • Front Silver
  • Dimensions: 240x124x90mm
  • Weight: 1.740kg
  • Supplied with IEC C14 mains cable
[Img-17738-left-thickbox_default]
[Img-17736-left-thickbox_default]
[Img-17737-left-thickbox_default]
AUDIOPHONICS Amplificateur TDA8954 Silver (Description)
Channel2 (Stereo)
