By buying this product you get 39 loyalty points
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
Power amplifier for Subwoofer 1x150W 8 Ohm - 1x230W 4 Ohm
The DAYTON AUDIO SA230 230W on 4 Ohm and 150W on 8 Ohm is the perfect subwoofer amplifier in an extremely well finished aluminium housing. Powerful and musical, it brings a real solution of a great simplicity of use with a stereo input, a button of power on, and various accessible adjustments in front. For a tight budget, it brings the ability to easily drive high quality subwoofers.
Its compactness and versatility allows the Dayton Audio SA230 to integrate with all audio systems, whether for HiFi or a Home Theater application. A thermal protection and an integrated short-circuit are also present to protect the unit.
The DAYTON AUDIO SA230 has several easily configurable settings. First the possibility to choose the gain provided by the amplifier, then the choice of the cutoff frequency (From 80 to 180Hz), and finally the phase adjustment (From 0 to 180°). These 3 settings guarantee a perfect integration of the SA230 in any listening environment.
Output power 8 Ohm | 156W |
Output power 4 Ohm | 233W |
Input | x1 Line RCA |
Output | x1 Line RCA Speaker terminal |
Input impedance | 12 KOhm |
Input sensitivity | 75mV |
Power supply | 110V or 230V (Adjustable switch) |
SNR | 85dB |
Active adjustable filter | 80Hz - 180Hz |
Adjustable gain | De 0 à +10dB |
Bass Boost function | 25Hz - 50Hz |
Low-pass adjustment | 80Hz - 180Hz |
Weight | 9.5kg |
Dimensions | 353 x 437 x 97mm |
Color | Black |
Input | RCA |
Output | RCA |
Output | Subwoofer |
Output | Speaker terminal |
Color | Black |
Channel | 1 (Mono) |
Class | Class A / AB |
Amplifier chip | N/A |
Power (W) | 230.0 |
Remote Control | No |
