DAYTON AUDIO SA230 Amplifier for Subwoofer 1x230W 4 Ohm Black
The DAYTON AUDIO SA230 from 230W on 4 Ohm and 150W on 8 Ohm is the perfect subwoofer amplifier in an extremely well finished aluminum housing.
By buying this product you get 39 loyalty points
Reference : 12611
399,00 €tax incl.
332,50 € tax excl.
This product is temporarily unavailable.
Attention: The product is delivered configured in 110V. If your electrical network provides a voltage of 220V (Europe), it is imperative to configure the device in 220V using the switch on the back of the device before connecting it to the mains. An incorrect setting could damage your device.
Dayton Audio SA230
Power amplifier for Subwoofer 1x150W 8 Ohm - 1x230W 4 Ohm
Dayton Audio SA230 Amplificateur de puissance subwoofer 1x150W 8 Ohm 1x230W 4 Ohm
High Fidelity and Power
The DAYTON AUDIO SA230 230W on 4 Ohm and 150W on 8 Ohm is the perfect subwoofer amplifier in an extremely well finished aluminium housing. Powerful and musical, it brings a real solution of a great simplicity of use with a stereo input, a button of power on, and various accessible adjustments in front. For a tight budget, it brings the ability to easily drive high quality subwoofers.
Its compactness and versatility allows the Dayton Audio SA230 to integrate with all audio systems, whether for HiFi or a Home Theater application. A thermal protection and an integrated short-circuit are also present to protect the unit.
Dayton Audio SA230
Adjustable phase, frequency, and gain
The DAYTON AUDIO SA230 has several easily configurable settings. First the possibility to choose the gain provided by the amplifier, then the choice of the cutoff frequency (From 80 to 180Hz), and finally the phase adjustment (From 0 to 180°). These 3 settings guarantee a perfect integration of the SA230 in any listening environment.
Output power 8 Ohm156W
Output power 4 Ohm233W
Inputx1 Line RCA
Outputx1 Line RCA
Speaker terminal
Input impedance12 KOhm
Input sensitivity75mV
Power supply110V or 230V (Adjustable switch)
SNR85dB
Active adjustable filter80Hz - 180Hz
Adjustable gainDe 0 à +10dB
Bass Boost function25Hz - 50Hz
Low-pass adjustment80Hz - 180Hz
Weight9.5kg
Dimensions353 x 437 x 97mm
OutputSpeaker terminal
OutputSubwoofer
Channel1 (Mono)
ClassClass A / AB
Amplifier chipN/A
Power (W)230.0
