By buying this product you get 160 loyalty points
The Denafrips Hyperion is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. The Hyperion is capable of delivering 2x80W into 8Ω or 2x150W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped with 4 pairs of output transistors.
In addition to its robust Class AB amplifier stage, the Denafrips Hyperion features an extensive power supply stage. This includes a large, custom-built 300VA shielded toroidal transformer, 18 high-capacity capacitors (147600µF) and a fast-switching schottky diode. Together, they provide the amplifier circuit with a clean, stable and more than adequate electrical signal.
Denafrips power amplifiers are symmetrical. Please do not connect the amplifier's speaker output to the high-level input of a subwoofer. Such a connection could potentially damage the amplifier.
1 | XLR input |
2 | Right channel speaker output |
3 | Power input |
4 | Left channel speaker output |
Product type | Discrete balanced power amplifier |
Amplification type | Class AB |
Output power (RMS) | 2x150W @ 4Ω 2x80W @ 8Ω |
Input | Balanced stereo XLR |
Output | Speaker terminals |
Input impedance | 22kΩ |
Input sensitivity | 1.8Vrms |
Gain | 26dB |
Frequency response | 10Hz - 80kHz (-2.2dB) |
THD+N | 0.00078% |
SNR | 125dB |
Dynamic range | > 121dB |
Crosstalk | -110dB |
Supply voltage | 100-240VAC 50/60Hz |
Consumption | Standby: 0.5W Operating: 234W |
Color | Black |
Dimensions | 320 x 380 x 100mm |
Weight | 16.5kg |
Package | 1x Denafrips Hyperion 12th Black |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 150.0 |
Remote Control | No |
