DENAFRIPS HYPERION 12TH Power Amplifier Silver
The Denafrips Hyperion is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. The Hyperion is capable of delivering 2x80W into 8Ω or 2x150W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped with 4 pairs of output transistors.
By buying this product you get 160 loyalty points
Reference : 18897
1 600,00 €tax incl.
1 333,33 € tax excl.
Shipping date: 22-04-2025.
Denafrips Hyperion 12TH Power Amplifier Balanced Discrete Class AB 2x150W 4Ω Silver
Denafrips Hyperion: Front view
In addition to its robust Class AB amplifier stage, the Denafrips Hyperion features an extensive power supply stage. This includes a large, custom-built 300VA shielded toroidal transformer, 18 high-capacity capacitors (147600µF) and a fast-switching schottky diode. Together, they provide the amplifier circuit with a clean, stable and more than adequate electrical signal.
Denafrips power amplifiers are symmetrical. Please do not connect the amplifier's speaker output to the high-level input of a subwoofer. Such a connection could potentially damage the amplifier.
Denafrips Hyperion 12Th : Connectors
Denafrips Hyperion: Connectors
1XLR input
2Right channel speaker output
3Power input
4Left channel speaker output
Product typeDiscrete balanced power amplifier
Amplification typeClass AB
Output power (RMS)2x150W @ 4Ω
2x80W @ 8Ω
InputBalanced stereo XLR
OutputSpeaker terminals
Input impedance22kΩ
Input sensitivity1.8Vrms
Gain26dB
Frequency response10Hz - 80kHz (-2.2dB)
THD+N0.00078%
SNR125dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
ConsumptionStandby: 0.5W
Operating: 234W
ColorSilver
Dimensions320 x 380 x 100mm
Weight16.5kg
Package1x Denafrips Hyperion Silver
InputXLR
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)150.0
DENAFRIPS HYPERION 12TH Power Amplifier Balanced Discrete Class AB 2x150W 4Ω Silver
The Denafrips Hyperion is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. The...
