By buying this product you get 245 loyalty points
The Denafrips Thallo is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. This is an improved version of the brand's Hyperion model. The Thallo is capable of delivering 2x120W into 8Ω or 2x220W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped with 4 pairs of output transistors.
In addition to its robust Class AB amplifier stage, the Denafrips Thallo features an extensive power supply stage. This includes a large, custom-built 600VA shielded toroidal transformer, 36 high-capacity capacitors (200400µF) and a fast-switching schottky diode. Together, they provide the amplifier circuit with a clean, stable and more than adequate electrical signal.
Denafrips power amplifiers are symmetrical. Please do not connect the amplifier's speaker output to the high-level input of a subwoofer. Such a connection could potentially damage the amplifier.
1 | XLR input |
2 | Right channel speaker output |
3 | Power input |
4 | Left channel speaker output |
Product type | Discrete balanced power amplifier |
Amplification type | Class AB |
Output power (RMS) | 2x220W @ 4Ω 2x120W @ 8Ω |
Input | Balanced stereo XLR |
Output | Speaker terminals |
Input impedance | 22kΩ |
Input sensitivity | 1.8Vrms |
Gain | 26dB |
Frequency response | 10Hz - 80kHz (-2.2dB) |
THD+N | 0.00125% |
SNR | 118dB |
Dynamic range | > 121dB |
Crosstalk | -110dB |
Supply voltage | 100-240VAC 50/60Hz |
Consumption | Standby: 0.5W Operating: 365W |
Color | Black |
Dimensions | 320 x 400 x 140mm |
Weight | 19kg |
Package | 1x Denafrips Thallo 12th Black |
Input | XLR |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class A / AB |
Amplifier chip | Transistors |
Power (W) | 220.0 |
Remote Control | No |
