DENAFRIPS THALLO 12TH Power Amplifier Silver
The Denafrips Thallo is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. This is an improved version of the brand's Hyperion model. The Thallo is capable of delivering 2x120W into 8Ω or 2x220W into 4Ω, while offering magnificent musicality and dynamics. Each channel is equipped with 4 pairs of output transistors.
By buying this product you get 245 loyalty points
Reference : 18908
2 450,00 €tax incl.
2 041,67 € tax excl.
Shipping date: 24-04-2025.
Denafrips Thallo 12th Power Amplifier Balanced Discrete Class AB 2x220W 4Ω Silver
Denafrips Thallo: Front view
In addition to its robust Class AB amplifier stage, the Denafrips Thallo features an extensive power supply stage. This includes a large, custom-built 600VA shielded toroidal transformer, 36 high-capacity capacitors (200400µF) and a fast-switching schottky diode. Together, they provide the amplifier circuit with a clean, stable and more than adequate electrical signal.
Denafrips Thallo: Internal view
Denafrips power amplifiers are symmetrical. Please do not connect the amplifier's speaker output to the high-level input of a subwoofer. Such a connection could potentially damage the amplifier.
Denafrips Thallo: Connectors
1XLR input
2Right channel speaker output
3Power input
4Left channel speaker output
Product typeDiscrete balanced power amplifier
Amplification typeClass AB
Output power (RMS)2x220W @ 4Ω
2x120W @ 8Ω
InputBalanced stereo XLR
OutputSpeaker terminals
Input impedance22kΩ
Input sensitivity1.8Vrms
Gain26dB
Frequency response10Hz - 80kHz (-2.2dB)
THD+N0.00125%
SNR118dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
ConsumptionStandby: 0.5W
Operating: 365W
ColorSilver
Dimensions320 x 400 x 140mm
Weight19kg
Package1x Denafrips Thallo 12th Silver
InputXLR
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)220.0
DENAFRIPS THALLO 12TH Power Amplifier Balanced Discrete Class AB 2x220W 4Ω Silver
The Denafrips Thallo is a totally discrete, balanced power amplifier, benefiting from a particularly well-designed Class AB architecture. This is...
