Architectured around the now famous to be knownTRIPATH TA2022, this new stereo power block is ideal for the most daring installations made up of multiple blocks.
This device develops 90 Watts per channel under 4Ω with 0.1% THD , a very satisfactory power capable of reviving an installation and which although seemingly limited, truly succeeds in surprising by its dynamics and its transparency.
This stereo power block has an input XLR balanced (mono for use in bridged mode) as well as an entry RCA Stereo switchable via a switch. (Switching the device off).
The integration of a Trigger input enables this power block to be switched on via a 12V signal sent, for example, by a preamplifier.
Its linear power supply with toroidal transformer in substitution of the conventional switching power supplies generally encountered on this type of product makes it possible to limit the harmful effects of the switchings and their harmonics on the high frequencies.
Theis made up of electrolytic capacitorssPanasonic FCand a150VA toroidal transformerwinding machine with overheating protection.
Subtle blend of finesse and firmness, this amplifier of great generosity provides joy and emotion as few others know how to do in this price range.
Warning, this amplifier may be sensitive to radio interference from FM radios and tuners./ P>
Specifications: Strong>
- Housing 100% Aluminum Li>
- Input Trigger for controlling the ignition by a preamplifier
- Class -T amplifier circuitTRIPATH TA2022
- Capacitors Panasonic FC
- Stereo use: Stereo line input RCA
- Mono Bridged use: Mono line input on XLR Symmetric Strong>or RCA
- High quality RCA Plated Gold Plated 24k
- Outings onHP insulated and gold-plated 24k and accepting cables of large cross-section Li>
- HP mono output on BTL screen-printed red connectors (input on white RCA / switching under device required)
- PuiOutput Channel:
- Mono Bridge (for 8ohm and + speakers): Strong>1 x 150W under 8Ω (0.1% THD + N)
- Total Harmonic Distortion Rate:0.05% (1 KHz)
- Frequency Response: 15Hz - 80kHz (-1db)
- Signal Noise Ratio:92dB
- Sensitivity Line Input: 2000mV
- Yield:Up to 90%
- Food :AC 110V-230V (± 10%) 50 / 60Hz Li>
- Maximum Power Consumption:150W
- Dimensions:165 x 260 x 60 mm
- Weight:3.7 Kg Li>
- Supplied mains cable Li>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
P>
[Img-10311-left-thickbox_default]
