TONEWINNER AD-1PA Power Amplifier Class A Stereo 2x300W 8 Ohm
Powerful Class A stereo power amplifier, the Tonewinner AD-1PA benefits from a high quality balanced architecture that allows it to develop significant power while ensuring a dynamic and precise sound reproduction. Its careful and intelligent integration, proof of the attention paid by the brand to their product, results in a powerful and musical device, respecting the audio signal to reveal every detail.
By buying this product you get 299 loyalty points
Reference : 17579
2 990,00 €tax incl.
2 491,67 € tax excl.
This product has been replaced by the Tonewinner AD-1PA+.
Tonewinner AD-1PA
Power Amplifier Stereo Class A 2x300W 8Ω
Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm
A Class A amplifier as powerful as it is efficient
The amplifier stage of the Tonewinner AD-1PA embeds 8 pairs of high power transistors TTC5200 and TTA1943 within a Class A. These allow the amplifier to deliver a consequent power of 300W RMS per channel under 8Ω.
Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm Tonewinner AD-1PA Amplificateur stéréo Class A 2x300W 8 Ohm
Class A/AB switch
The Tonewinner AD-1PA has three operating modes: Class A, Class AB or Auto. A switch allows you to select the most suitable mode according to your needs and your installation. The Auto mode automatically switches from Class A to Class AB when the temperature of the unit reaches a certain limit and switches back to Class A if the temperature drops.
Bi-wiring possibility
With its dual speaker terminals, the Tonewinner AD-1PA offers the possibility of bi-wiring. This method of connecting to speakers can offer an improvement in sound quality by reducing the magnetic interactions of the cables.
A large power supply
In order to deliver such a power, the Tonewinner AD-1PA is equipped with a large power supply, including a high performance toroidal transformer of no less than 1200W. 16 large filter capacitors with a total capacity of 180,000µF ensure a clean and stable electrical signal. In addition, the left and right channels are independently power supplied.
Perfect isolation
The internal design of the AD-1PA has been thought to physically separate the different sections of the device and thus ensure a very good isolation. This design effectively limits interference and noise.
Product typePower amplifier
ChannelsStereo (2)
Amplification typeClass A
Class AB
Inputs1* Single-ended stereo RCA
1* Balanced stereo XLR
OutputsSpeaker terminals
TriggerInput and output
Output power300W RMS/channel @ 8Ω, 20Hz-20kHz, THD < 0.1%, two driven channels
500W RMS/channel @ 4Ω, 20Hz-20kHz, THD < 0.1%, one driven channel
320W RMS/channel @ 8Ω, THD < 0.1%, one driven channel
Pure class A output power100W @ 8Ω
Impedance8Ω
Channel separation≥ 80dB
Bias selectionClass A
Class AB
Auto
Speaker output modeA
B
A+B
Frequency response10Hz-100kHz (+1/-3dB)
THD+N< 0.008% @ 1kHz
SNR≥ 108dB (A-weighted)
Recommended minimum load impedance (per channel)2Ω
Damping factor> 200 @ 8Ω
Input sensitivity1.6V @ rated power, 8Ω
Gain29.5dB ±1dB
Geenral
Supply voltage110-240V AC 50/60Hz
Dimensions444*294*449
Net weight43.4kg
Housing materialAluminum
ColorBlack and silver
Package1* Tonewinner AD-1PA
1* Power cable
InputXLR
OutputSpeaker terminal
ColorSilver
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)300.0
Powerful Class A stereo power amplifier, the Tonewinner AD-1PA benefits from a high quality balanced architecture that allows it to develop...
