Audiophonics offers here cables in kit for more ease.
All necessary components are provided to build a complete high end power cable based on FURUTECH products.
This kit includes:
- 2.5 m FURUTECH FP-314AG Copper Sector Cable Silver Plated μ-OFC (Alpha α)
- 1x FURUTECH FI-11CU IEC connector
- 1x FURUTECH FI-E11CU Plug SCHUKO
Result when mounted:
If you want this cable mounted, we offer a mounting package.
Please go tothe following card to take advantage of our offer:
High-performance 3 conductorsdedicated to audio applications without compromise, the FP-314AG testifies to a manufacturing quality and a technicality that leaves no doubt as to its belonging to the FURUTECH range.
Specifications:
- Cable Sector 3 DriversHigh performance
- Pole conductors Section 1.85mm² Consisting of 37 Copper Strands μ-OFC (Alpha) Silver Plated of each one0.25mm Diameter
- Earth conductorsSection 1.85mm² Consisting of 37 Copper Strands μ-OFC (Alpha) of each one0.25mm Diameter
- Insulatingpolyethylene 3.4mm Diameter Marked with a color code (Red / Green / White)
- Shielding Braided from 9 x 24 μm OF-copper wire (Alpha) of each 0.12mm of Diameter
- PVC Envelope BlackHigh resistance and capable of high Flexibility
- Diameter Total du Câble: 13mm
- Color code: Red = Phase / White = Neutral / Green = Earth
Cable also sold by meter
IEC connector specifications :
- Conductors: Copper alloy treated with the "Furutech Alpha α" anti-magnetism process
- Insulation: Nylon / Fiberglass
- Housing: Polycarbonate
- This connector adapts to an external cable diameter of 6.6mm up to 18mm
- 250V / 10A
- Dimensions:
- Diameter: 38mm
- Body Length: 48.2mm
- Overall Length: 74mm
IEC connector also sold individually
Schuko Connector Specifications :
- Connectors Schuko 3 Screw Connectors
- Plating:Or 24k 3μ
- Maximum Driver Section:16mm²(4.5mm of Diameter)
- Maximum Cable Diameter: 16.5mm
- Voltage / Voltage Rating: 16A / 250V
- Overall Length: 89 mm
- Diameter: 38 mm
- Weight: 75 g
Schuko connector also sold individually
