DIY Furutech cable kit FP-3TS20 + FI-11-N1G / FI-E11-N1G 2.5m
Audiophonics offers here cables in kit for more ease.
All necessary components are provided to build a complete high end power cable based on FURUTECH products.
This kit includes:
Result when mounted:
If you want this cable mounted, we offer a mounting package.
Please go tothe fiche nextto take advantage of our offer:
FURUTECH FP-3TS20 High-End Power Cable Copper μ-OCC (Alpha α)
Very high performance mains cable 3 conductorsdedicated to Uncompromised Audio Applications, the FP-3TS20testifies to a quality of manufacture and a technicality that leaves no doubt as to its positioning high-end.
Specifications:
- Cable Sector 3 DriversVery High Performance
- 3 Drivers ofSingle Section 2.16mm² Consisting of a total of 85 Copper Strands μ-OCC (Alpha) of each one0.18mm Diameter
- Insulatingpolyethylene of 3.53mm Diameter Covered with a Teflon film and marked with a color code (Red / White / Yellow)
- Internal wrapping inPVC Black High Flexibilityof 9.6mm of Diameter
- Braided Shielding 9 x 24 μm OF-copper wire (Alpha) of 0.12mm of Diameter
- Envelope ExtPVC Blue Night(Dark blue)very high resistance
- Maximum Resistance of Conductors:0.008Ω / M
- Total Cable Diameter: 14.3mm
- Color code: Red = Phase / Yellow = Neutral / White = Earth
Cable also sold at the cut
IEC connector specifications :
- Conductors: Phosphor bronze plated 24k gold treated with the anti-magnetism process "Furutech Alpha α"
- Jumper system for disconnection of the mass
- Insulation: Nylon / Fiberglass
- Housing: Polycarbonate
- This connector adapts to an external cable diameter of 6.6mm up to 18mm
- 250V / 10A
- Dimensions:
- Diameter: 38mm
- Body Length: 48.2mm
- Overall Length: 74mm
IEC connector also sold individually
Connector specifications schuko :
- 250V / 16A
- Dimensions:
- Diameter: 39mm
- Body Length: 56mm
- Overall Length: 88mm
Schuko connector also sold individually
