Kit cable DIY Audiophonics Sector PCG3 Shielded 3x2.5mm² 1.00m
4.0 / 5
Reference : 2359
16,90 €tax incl.
14,08 € tax excl.
Audiophonics markets its audio cables in kit so you can enjoy the quality of its equipment at a lower cost.
All necessary components are supplied to build a cable identical to the mounted version.
  • Each 2.5mm² conductor consists of 50 strands of 0.25mm copper
  • High impedance PVC insulation (> 20 Gohm x cm)
  • Electromagnetic shielding (EMI) by a tinned copper braid with low coupling resistance (250ohm / km @ 30MHz)
  • Phase reversal Schuko connector
  • Braided nylon outer sheath
  • Diameter 13mm
If you want this cable mounted, we offer a mounting package.
Please go to
the following form to take advantage of
e our offer:
https://www.audiophonics.fr/images2/5188/5188_CABLE_ASSEMBLY_5.jpg
Result once the mounted cable:
https://www.audiophonics.fr/images2/2359/2359_POWER_CABLE_KIT_PCG3_1.jpg
https://www.audiophonics.fr/images2/2359/2359_POWER_CABLE_KIT_PCG3_2.jpg
IEC connector:
https://www.audiophonics.fr/images2/7719/7719_WIRABLE_IEC_C13_GOLD_1.jpg
2 reviews
TRES BON KIT
très bon produit, montage simple, très robuste. A conseiller
This review has been posted for Kit cable DIY Audiophonics Sector PCG3 Shielded 3x2.5mm² 1.00m
Très bonne qualité de l'ensemble, sauf reproche je conseillerais de monter des prise de plus haute gamme si vous souhaitez utilisé la masse avec la terre les diamètres des connecteur interne des prises est vraiment trop petit, obligation de supprimé la moitié de la masse tressé dommage.
