Kit Cable DIY ELECAUDIO JDC-121 Power supply Jack DC 2.1 to DC 2.1mm 1m
Reference : 9999
26,90 €tax incl.
22,42 € tax excl.
Instead of 34,30 €
Pack content
Audiophonics offers cables in kit so you can enjoy the quality of the ELECAUDIO range at a lower cost.
All necessary components are supplied to build a cable identical to the mounted version.
The choice of materials has been scrupulously studied and the smallest details are checked to offer you a high-end cable.
Paparticularly robust and well finished, the Jack DC ELECAUDIO DC-2.1Gare equipped with a clamping system and the contacts are plated Gold 24K.
The conductors are composed of 147 strands of 0.12mm bearing the 1.6mm² section of Copper with FEP insulation.
These conductors are then protected by an ELECAUDIO ADIACIUM BG nylon sheath with irreproachable finishes.
This cable was developed for music lovers looking for an optimal quality without loss for a great efficiency above all.
Features:
  • Conductor: ELECAUDIO FC116T Copper OFC Ø 2.2mm
  • Section: 7x 21 strands of 0.12mm ie 1.6mm²
  • Connectors: Jack DC 5.5 / 2.1mm ELECAUDIO DC-2.1GGold plated 24K
  • FEP Insulation
  • Nylon sheath ELECAUDIO ADIACIUM BG 4-11mm
  • Length: 1m
  • Weight: 80g
Length (m)1.0
Number of conductors2
Insulation materialFEP
Section (mm²)1.64
ConnectorJack DC
Sérieux
C'est du sérieux, produit de qualité c'est solide.
Le son est largement au dessus de la moyenne
Ste sérieuse !
This review has been posted for Kit Cable DIY ELECAUDIO JDC-121 Power supply Jack DC 2.1 to DC 2.1mm 1m
