1877PHONO LEGION Shielded Power Cable OFHC Schuko IEC C19 3x3.31mm² 2.5m
By buying this product you get 44 loyalty points
Reference : 12280
449,00 €tax incl.
374,17 € tax excl.
Shipping date: 22-04-2025.
1877PHONO LEGION: Shielded Shielded Cable Schuko IEC C19 2.5m
1877PHONO offers with its LEGION range exceptional power cables, which will contribute to provide your system with a clean power supply, for a sound reproduction at the most just.
Câble alimentation blindé 1877Phono Legion Schuko C19
An exceptional design
The 1877Phono Legion mains cable is made of very high-purity OFHC copper conductors, with a dielectric multilayer shielding. It was the many years of know-how and experience that enabled the 1877Phono technicians to develop this exceptional cable.
This cable allows you to provide your devices with power without interference, and especially in a stable and without degradation. The Legion's robust design and appearance provides a powerful image, in line with its performance.
Want to improve toujbe more performance of your system? You can pair the excellent Legion cables with the Powergrip YG-1, powerful distributor and mains filter with 11 Schuko plugs. It will allow you both to protect your system from overloads but also to significantly reduce noise.
Attention: The Powergrip is sold separately.
Connector IEC C19
This model of the Legion cable of 1877Phono differs by its connector IEC C19. A specific format connector that can be found on some Hifi devices, such as the Audio Research VS115 tube amplifier.
Team Viewed:/ Span>Amazing quality and price not found in this price range. Beware, however, of the rigidity of the cable and consequently of its small radius of curvature.
  • Connectors: 1x Schuko male, 1x IEC C19
  • Conductors: Copper Finland OFHC 99.998% purity
  • Section: 3 x 3.31mm² with fine strands
  • Triple shielding: Braid + Feuillard + Drain
  • External anti-static sheath
  • Cable Diameter: 23.5mm
  • Gold plated connectors
  • Length: 2.5m
Length (m)2.5
ShieldingYes
Section (mm²)3.30
ConnectorSchuko
ConnectorIEC C19
