1877PHONO OCC Silver Dart Shielded Power Cable 3x5.26mm² 1.5m
Here is the OCC Silver Dart power cable by 1877Phono, having OCC Crystal Copper conductors of 3x5.26mm². The latter is the culmination of 3 years of development and testing using their proprietary "H-Wound™.
3.0 / 5
By buying this product you get 99 loyalty points
Reference : 11462
999,00 €tax incl.
832,50 € tax excl.
Shipping date: 24-04-2025.
Here is the OCC Silver Dart power cable by 1877Phono, having OCC Crystal Copper conductors of 3x5.26mm². The latter is the culmination of 3 years of development and testing using their proprietary "H-Wound™ technique combined with their HDPE doped graphene drivers. Thanks to this technique, each of the 6 cores is guaranteed "Zero Loss" just before the application of the final layer of OCC Silver. 100% of the cores are identical before they are attached to the Audiophile sector connectors.
The OCC Silver Dart cable conductors are "Cryo-treated" before extrusion and then undergo their thermal cleaning process to remove any external dirt: oils, residues, following extrusion. This high voltage DC cleaning gives the OCC Silver Dart the performance of a top of the range cable that has been running for several months.
Their new "HDPE Doped Graphene" technique adds an extra layer of protection to the cable, which further reduces EMI/RFI without stifling power input, which can occur on some cables when adding braiding.
The 1877Phono cable uses the "Cable in Cable" principle, a controlled technical space that insulates the cable even more and gives it a total diameter of 23mm. One could almost say that this cable uses another power cable in its interior, which allows it to obtain an unequalled sound signature.
This cable is particularly suitable for power amplifiers, tube amplifiers, and devices requiring large powers to give the maximum of them.
The performance of the 1877Phono OCC Silver Dart is unmatched, no transfer restrictions, raw power that adds no color to your components, and also protects your equipment from external interference or interference.
You will find in the "Download" tab of this page a PDF explaining the graphene dielectric shielding of this cable 1877 PHONO DART Graphene cable shielding technology
General characteristics:
  • Conductors: Copper OCC Crystal
  • Section : 3x5.26mm² (10AWG) / H-Wound™
  • 6 insulation cores filled with cotton
  • PVC resistant up to 105°C
  • High density "EVA Vibrations" plugs
  • Antistatic braided outer sheath
  • Total cable diameter: 23mm
  • Connectors: Schuko to IEC C13 24k Gold Plated
  • Length: 1.5m
  • Delivered with a transport bag with shoulder strap: 35x45cm
Length (m)1.5
ShieldingYes
Section (mm²)5.26
ConnectorIEC C13
Câble à Privilégier pour les équipements à consommation constante
Je peux certainement me tromper mais je dirais que les câbles d'alimentation très isolés comme ce câble, ont un effet négatif sur la dynamique de la musique si vous alimentez un ampli de puissance ou intégré : il y a comme un effet passe-bas, un amortissement très audible (augmentation des graves, diminution des aigus). La musique perd en vie. L'ampli n'arrive pas à suivre fidèlement les sollicitations de la musique.
Par contre, il peut s'avérer intéressant pour alimenter une source (transport) ou un Dac, éventuellement un préampli dont les besoins en courant sont quasi constants.
Remarque : c'est un câble de bonne facture.
This review has been posted for 1877PHONO OCC Silver Dart Shielded Power Cable 3x5.26mm² 1.5m
Here is the OCC Silver Dart power cable by 1877Phono, having OCC Crystal Copper conductors of 3x5.26mm². The latter is the culmination of...
