By buying this product you get 149 loyalty points
Shielded Power Cable Schuko IEC C19 3x5.26mm² 2.5m
The 1877Phono Silver Dart OCC power cable is the result of 3 years of development and testing on aspects of mechanical transmission, EMI / RFI pollution and the quality of the materials used. The Silver Dart OCC today offers a quality of signal transmission and restitution equivalent to the best high-end productions on the market, capable of being compared to American and European references.
The H-Wound structure is a threading technique allowing a high quality fill rate with 16,000 spirals/turns per meter, without loss of strands during the manufacturing process.
The high precision of assembly and clamping guarantees the same number of strands and the same cross-section for each conductor all the way to the end of the final connection, which every enthusiastic hobbyist has the right to expect from a top-of-the-range mains cable. This high-resolution cable has a cable-in-cable construction. After the sheath, there is a conventional EMI protective layer separated by two layers of cotton strands. This acts as a mechanical vibration decoupling with the conductive and dielectric graphene part of the cable.
The Silver Dart series conductors and strands are made of high-purity OCC Copper and OCC Silver, undergoing several treatments. These treatments improve conductivity and signal transmission for accurate sound reproduction.
This is a cryogenic treatment at two temperature levels, -186°C and -196°C, depending on the nature of the material used. This treatment allows the conductor crystals to be optimized with the sole aim of providing the best possible signal transmission.
After extrusion, the Silver Dart's strands go through a high voltage thermal surface cleaning process, close to electrolysis and more efficient than cleaning with a conventional cleaning agent. The result is high purity, completely removing extraction oils and surface heating residues. This process also results in a ready-to-use cable that is already grounded and offers an optimal result from the very first notes of music on a high-end HiFi system.
1877Phono Zavfino is the first manufacturer in the world to integrate a screen protector with Graphene, an unparalleled advanced material. It rejects EMI / RFI interference and offers a high level of high quality micro-details. Graphene is also an excellent protector against electrostatic discharges affecting the signal flowing on the surface of the strands.
You will find a complete article in PDF format on the advantages of Graphene : ZGRAPH LDP 1877Phono.
Product type | Power cable |
Connectors | Schuko IEC C19 |
Length | 2.5m |
Material of the cable conductors | OCC Copper Silver |
Conductors section | 5.26mm² (10AWG) H-Wound™ Technology |
Connectors contacts plating | Gold 24k |
Dielectric | High absorption graphene PTFE LDPE |
Specific treatments | Deep Cryo Treated : low temperature treatment at -186°C and -196°C |
Sheath | Anti-static braided sheath |
Cable finish | Anti-vibration EVA |
Cable total diameter | 23mm |
Length (m) | 2.5 |
Shielding | Yes |
Section (mm²) | 5.26 |
Connector | IEC C19 |
Connector | Schuko |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
