1877PHONO PRIMA-OCC MK2 Power Cable OCC Copper 4.17mm² 1.5m
The 1877Phono Prima-OCC MKII power cable is an improved version of the NOVA-OCC with larger conductor cross section. Resolutely top-of-the-range, both in its superb finish and in the choice of materials that compose it, it will allow you to significantly improve one of the most impotent links of your system.
By buying this product you get 55 loyalty points
Reference : 14861
559,00 €tax incl.
465,83 € tax excl.
1877Phono Prima-OCC MKII Câble secteur Cuivre OCC 4.17mm² 1.5m
Featuring multi-stranded PC-OCC Copper conductors, it will bring out all the micro details of your favorite music.
Deep Cryo Treatment
Each conductor undergoes Deep Cryo treatment. This consists in cooling the conductors between -186°C and -196°C. To define the exact temperature to which the conductors must descend, 1877Phono studies the purity, size and molecular structure of each conductor. This treatment makes it possible to obtain more convincing silences, to improve bandwidth and dynamics.
xxx
xxx
Ultra Sonic 7 Treatment
This is a two-step process. In the first step, the bare conductor is passed through a ceramic mold in an ultrasonic cleaning chamber. This process removes impurities and imperfections from the surface of the wire down to the molecular level. Once each wire has been treated, they are bundled together for further treatment. During this second step, the voltage is increased while remaining below the conductor's threshold. This adjustment provides a running-in effect in addition to the 30 to 40 hours of signal and/or current that each wire receives. The Ultra Sonic 7 and Deep Cryo treatments allow the cable to be prepared to run in in a few days rather than several months once at the user's premises.
Product typePower cable
ConnectorsSchuko
IEC C13
Length1.5m
Conductors materialPC-OCC Copper
Conductors section4.17mm² (11AWG)
ConnectorsGold 24k
Cores insulationLDPE Dielectric
Cable insulationPTFE
TEF
ShieldingAluminum braid
FillingCotton
TreatmentsDeep Cryo
Ultra Sonic 7
SleevesEVA Anti-vibration
Braided sheathAnti-static
Anti-abrasion
Cable diameterØ23mm
Length (m)1.5
ShieldingYes
Section (mm²)4.17
ConnectorSchuko
ConnectorIEC C13
The 1877Phono Prima-OCC MKII power cable is an improved version of the NOVA-OCC with larger conductor cross section. Resolutely top-of-the-range,...
