Je n'y croyais pas au câbles d'alimentation ! Je peux vous qu le son est nettement meilleur et il ,n'y a pas photos !
Power Cable Schuko IEC C15 Silver Plated OCC 7N Copper Double Shielding 1m
With the Flagship, ATAudio offers a power supply cable with an exceptional design at a reasonable price. The special design consists of three silver-plated 7N OCC copper conductors for excellent electrical conductivity. Each is then insulated with a double layer of polyethylene. The side cables are also double shielded with first a silver-plated copper braid and then an aluminum foil, eliminating possible EMI interference and thus maintaining a clean and stable electrical signal.
The connectors are gold-plated, providing very good conductivity and resistance to oxidation. The body of the connectors is injected with carbon, again to reduce interference, while giving the cable a unique design.
Product type | Power cable |
Length | 1m |
Connectors | 1x IEC C15 1x Male Schuko |
Conductors | Silver plated 7N OCC copper |
Shielding | Silver plated copper braid Aluminum foil |
Connectors contacts plating | Gold |
Cable thickness | 10mm |
Cable width | 26mm |
Connectors diameter | Ø40mm |
Color | Blue |
Length (m) | 1.0 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | IEC C15 |
Connector | Schuko |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
