AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshops in France. It only includes high quality components, selected for their electrical performance and their ability to transmit a clean signal.
4.9 / 5
Reference : 11846
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 16-04-2025.
Audiophonics Stealth Câble Secteur Schuko C13 Cuivre OFC Blindé 3x3.5mm² 1.5m
Elecaudio CS-331B Cable
The Elecaudio CS-331B is a power cable that integrates materials and technologies usually reserved for products with much higher prices. Thus, each conductor consists of 7 strands, themselves composed of 10 strands of OFC Copper with a diameter of 0.25mm each, for a cross-section per conductor of 3.5mm².
These 3 conductors are individually insulated by a PVC sheath and held in place by a Cotton insert providing both flexibility and firmness to the assembly..
The cable also has double shielding. The first one uses an Aluminium strip, while the second one is a screen made of finely braided Copper. Between these two shields, an OFC Copper drain wire runs through the entire cable to ensure a linear grounding to ensure reinforced protection against radio (RFI) and electromagnetic (EMI) interference.
The unit is protected by a thick 3.5mm thick PVC protection sheath, ensuring excellent cable durability. The cable is finally covered by a Viablue braided nylon sheath with the most beautiful effect.
Elecaudio PS-24GC and PI-24GC connectors
The Audiophonics Stealth is equipped with a Schuko Elecaudio PS-24GC connector and a IEC C15 Elecaudio PI-24GC. They have a transparent nylon body, allowing the inside of the connector to appear. All the metal parts and in particular the contact and ground parts are 24k Gold plated on a thickness of 3µ. This plating provides greater resistance to oxidation but also very good signal conductivity. In the Schuko connector, the conductors are placed in a Viablue OFC Copper protective tips and allow better contact with the connector clamping system.
Product typePower cable
Length1.5m
Connectors1x Schuko (Elecaudio PS-24GC)
1x IEC C15 (Elecaudio PI-24GC)
Connectors platingOr 24k 3µ
Cable conductors3x 3.5mm², OFC Copper
Cable shieldingAluminium foil
Copper braid
Cable conductors insulationPVC
Cable fillingCoton
Cable sheathPVC, 3.5mm
Cable covering sheathExtensible braided sheath, Nylon PET, Black (Viablue)
Cable diameterØ16mm
Voltage / Current250V / 16A
ColorsCable: Black
Connectors : Transparent and Black
Weight550g
Length (m)1.5
ShieldingYes
Section (mm²)3.50
ConnectorSchuko
ConnectorIEC C13
22 reviews
Good!
I was buy three of them and must say that this cable is top quality and is hard to find better power cables for the price.
Cable comes in nice corduroy bag wich tells us that is made with care.
It is on "the fat" side so take care of the place behind your equipment.
Didn't notice any sound difference, but at least i know that my equipment is well protected and i can sleep peacefully.
As always, great customer service at Audiophonics and fast shipping.
Will definetly buy again
This review has been posted for AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² 1.5m
Acheté par curiosité en remplacement d'un AUDIOPHONICS Câble secteur blindé OLFLEX 110CY 3x2.5mm² 1.15m en place depuis un moment, qui alimente un conditionneur Ludic Heimdall.
Pas de panique! en toute première écoute, effet loupe sur les basses (boursouflées), mediums proéminents et aigus agressifs avec accentuation des sifflantes. Aie!!
Mais tout de suite, amélioration de de la scène sonore toutes sources confondues : élargissement, projection vers l'avant, amélioration du centre disposé bien plus en avant du plan des enceintes. Amplification des micro détails déjà identifiés, apparition d'autres bien plus ténus. Bon..
Les basses rentrent dans le rang en premier: plus de profondeur, meilleur découpage et lisibilité, plus d'amplitude surtout à la lecture des vinyles.
Les médiums et aigus suivent, avec conservation du gain sur la scène et les micro détails. Le centre se stabilise dans une belle présence, vraiment agréable.
les aigus s'assagissent vraiment, soyeux, vifs et précis, mais sur mon système je note un léger tassement surtout à la lectures de CDs, et de certains vinyles, mais pas sur tous. Le dac est trés peu impacté.
Le câble respire la qualité, il est beau, de gros diamètre, assez raide mais pas trop gênant de ce point de vue. Les prises sont belles, et le grip très bon.
En conclusion un très bon câble ,excellent chez moi, au détail des aigus près (à voir la suite), plus de coffre, plus de basses, plus de scène sonore, qui fera beaucoup sur des systèmes remontants, après 50 bonnes heures de rodage minimum.
Bonnes écoutes!
Intégré push pull KT90, enceintes monitor audio Silver 500 6G, CD eera, Dac D50s, riaa Lehmann audio black cube SE2, cellule Mc Audio Technica, rca Harmonic technology, secteur sources Wireworld Aurora.
cable
Câble de bonne qualité , gain important dans les basses et une densité plus importante du rendu général ainsi qu'une image stéreo plus stable.
bon produit.
L'affaire du siècle !
Ancien cablo-sceptique j'ai commençé mon éducation CS avec ce formidable câble.
Aujourd'hui j'ai des câbles plus chers, mieux "côtés", mais j'affirme haut et fort qu'il fait mieux que certains, que d'ailleurs je revends au fur et à mesure.
Bref c'est un mètre-étalon, et à ce prix il ne faut vraiment pas s'en priver.
testé sur des sources, sur des pré-amplis et des blocs de puissance, c'est bon partout !
Pour débuter, et même après pour continuer, c'est vraiment un produit terrible; Dynamique, ouvert, aéré, percutant, il à tout bon.
Merci Audiophonics, ne changez pas la recette svp !!!!!!!!!
Jyrki
Dry and precise. No Color the sound. Hard, not soft.
I recommend.
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end...
