AUDIOPHONICS STEALTH Power Cable US NEMA Type B to IEC C15 OFC Copper Shielded 3x3.5mm² 1.5m
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshops in France. It only includes high quality components, selected for their electrical performance and their ability to transmit a clean signal.
Reference : 17399
89,00 €tax incl.
74,17 € tax excl.
Shipping date: 24-09-2026.
Audiophonics Stealth Câble Secteur US NEMA Type B vers IEC C15 Cuivre OFC Blindé 3x3.5mm² 1.5m
The power cable is the first element in a HiFi system, so its quality should not be neglected. We offer you the Audiophonics Stealth, a high-end power cable designed in our workshop in France. This one integrates only high quality components, selected for their electrical performances and their capacity to transmit a clean signal.
Elecaudio CS-331B Cable
Elecaudio's CS-331B is a power cable that integrates materials and technologies usually reserved for products with much higher prices. Thus, each conductor is made of 7 strands, themselves composed of 10 OFC copper strands with a diameter of 0.25mm each, for a section per conductor of 3.5mm².
These 3 conductors are individually insulated by a PVC sheath and maintained thanks to a cotton pad providing both flexibility and firmness to the whole.
The cable also benefits from a double shielding. The first one uses an aluminum foil, while the second one is a screen made of finely braided copper. Between these two shields, an OFC copper drain wire runs the entire length of the cable to provide a linear grounding for enhanced protection against radio frequency interference (RFI) and electromagnetic interference (EMI).
The whole cable is protected by a thick 3.5mm PVC jacket, ensuring excellent durability. The cable is finally covered by a Viablue Nylon braided sheath of the most beautiful effect.
Viborg VM503G and VF503G Connectors
The Audiophonics Stealth is equipped with a US NEMA Type B Viablue VM503G connector and an IEC C15 Viborg VF503G connector. The latter have a glossy black Bayer-2805 polycarbonate body. All the metal parts and especially the contact and ground poles are made of pure copper with triple plating of OFC copper, silver and 24k gold. These ensure a perfect electrical conductivity and resistance to oxidation.
Product typePower cable
Length1.5m
Connectors1x US NEMA Type B power connector (Viborg VM503G)
1x IEC C15 (Viborg VF503G)
Cable conductors materialOFC Copper
Cable conductors section3*3.5mm²
Cable shieldingAluminum foil
Braided copper
OFC Copper drain wire
Cable conductors insulationPVC
Cable fillingCotton
Cable sheathPVC (Ø3.5mm)
Cable covering sheathBraided Nylon PET (Viablue)
Cable diameterØ16mm
Connectors contacts materialPure copper
Connectors contacts platingOFC Copper
Silver
Gold 24k
Weight650g
Length (m)1.5
ShieldingYes
Section (mm²)3.50
ConnectorIEC C13
ConnectorSchuko
2 reviews
Très bien
Parfait sur mon ampli à tubes Audiomat Arpège ref10. Répond parfaitement à mon besoin en termes de dimensionnement, sans tomber dans les câbles ésotériques.
This review has been posted for AUDIOPHONICS STEALTH Power Cable US NEMA Type B to IEC C15 OFC Copper Shielded 3x3.5mm² 1.5m
Nice powercord
Incredibly good build quality, comes in a nice bag.
Seems to cost significantly more.. and now to the sound.
To your ears, it is very neutral, pulls a bit towards the softer and dark side, but with all the details.
Very good quality overall.
The workshop built it with Eu contact.
The power cable is the first element in a HiFi system, so its quality is not to be neglected. We offer you the Audiophonics Stealth, a high-end...
