By buying this product you get 2276 loyalty points
Power Cable Schuko IEC C15 Silver Plated OCC Copper Alpha Treated NCF 1.8m
Project V1 is Furutech's ultimate high-end power cable. It is the culmination of more than 30 years of research by the brand into all aspects of electrical and signal transmission for high-end audio applications. The Project V1 features Furutech's groundbreaking technologies, patented designs and the highest quality materials, including:
The Project V1 power cable incorporates special connectors exclusive to this model: an IEC connector, a Schuko connector, and damping rings using Furutech's anti-static, anti-resonant NCF material combined with special, high quality nylon insulation. The bodies of these special connectors and damping rings are made of a four-layer NCF hybrid carbon fiber, finished with a clear, cured damping coating.
The contacts of the connectors are made of pure Alpha (α) treated non-magnetic Rhodium plated copper and fixed in insulated bodies with NCF material. The NCF material provides the purest electrical transmission without coloration, improving the depth and focus of the soundstage, harmonics and tonal balance. The low frequencies are better defined, with better definition thanks to a lower noise floor.
As for the conductors of the Project V1 cable, they are made of three distinct layers: the first is made of Silver-plated OCC Copper, the second and the last of ultra-high purity DUCC Copper, all materials taking advantage of the brand's Alpha (α) treatment. The high purity ultra crystallized DUCC Copper, supplied and regulated with strict quality control by Mistubishi Materials Industries, is one of the best conductors found by Furutech for signal transmission. Mitsubishi processes this extremely pure oxygen-free copper with a new technology that optimally aligns the crystals to achieve a highly efficient conductor. Furutech combines DUCC with its famous α-OCC Copper and processes this combination with the Alpha (α) cryogenic and demagnetization process to significantly advance purity and conductivity.
The cable sheaths have been designed to limit resonance and the impact of mechanical stress, while maintaining a certain flexibility. They are made of high-end damping polypropylene and hard cross-woven fiber (0.02mm soft polypropylene / 0.25mm hard polypropylene).
Integrated in a selection of Furutech products, NCF is based on a special crystalline material with two active properties. First, NCF generates negative ions that eliminate static electricity. Secondly, it converts thermal energy into infrared. Furutech combines this material with Ceramic nano particles and Carbon powder for their piezoelectric damping properties. Furutech thus obtains the optimal electrical and mechanical damping material.
Product type | Power cable |
Connectors | 1x Male Schuko 1x IEC C15 |
Length | 1.8m |
Conductors | Silver plated OCC Copper, Alpha (α) treated High purity DUCC Copper |
Sheath | Polypropylene |
Connectors body materials | Nylon Carbon fiber NCF |
Connectors contacts material | Alpha (α) treated pure Copper |
Connectors contacts plating | Rhodium |
Cable diameter | Ø32mm |
Color | Black |
Length (m) | 1.8 |
Shielding | NC |
Section (mm²) | N/A |
Connector | IEC C15 |
Connector | Schuko |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | Silver |
