FURUTECH The Astoria E Plus Professional Power câble Pur Copper Alpha 1.5m
By buying this product you get 84 loyalty points
Reference : 11371
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 03-07-2026.
If you're a musician or recording studio professional, ask yourself this question: Does a Hifi power cord make sense?
The new Furutech Astoria power cords have been designed with the demanding professional in mind. Developed in Tokyo with many talented musicians and recording professionals, Astoria power cords have been specially optimized and balanced to deliver more punch and dynamics to your mixes and studio recordings.
In fact, choosing the Astoria Furutech power cord gives you even more control over the kind of sound you're trying to achieve. Choose Astoria if you're aiming for fast response and natural speed, coupled with deep, powerful bass.
Simply replace the existing power cords for your amplifiers, mixing consoles, mic preamps and even your entire recording system, and you'll immediately hear greater sound coherence across the entire bandwidth. Dynamic range will be greater than ever, music will sound effortless and expansive instead of flat, aggressive or undefined.
Furutech's legendary design team are experts at preserving the audio signal path, delivering a precise, honest and uncompromising end result.
The PC-Triple C (Alpha) power cable used on the Astoria is the result of an exclusive fusion process involving repeated cycles of metal bending, a Katana-inspired technique refined over centuries of Japanese swordsmanship.
This art-like technique uses high-purity, oxygen-free copper. This creates a forging process identical to that of folded steel from the art of the Katana, shaped tens of thousands of times.
This ensures that the joints between the crystal grains inside the copper are rearranged so that the electrical current moves through the signal path more smoothly than ever before.
Add Alpha-treated gold-plated connectors, flexible ROHS PVC sleeving and a patented floating grounding system, and you've got a high-precision tool for extracting the best from music in the studio and on stage.
Features :
  • Fitted with Furutech FI-11M (Cu) or FI-E11 (Cu) and FI-11 (Cu) IEC mains sockets
  • Shielding and conductors treated α (Alpha) for protection against radiated noise
  • Flexible PVC ROHS sheath improves vibration isolation
  • Floating field Damper ™ US Patent No .: 6669491 / European Patent (EP1445837)
Cable specifications :
  • Number of connectors: 80 PC Triple C 0.18mm x 3 cores
  • Insulation: audio quality soft PVC (brown, light blue, green with yellow stripes)
  • Approx. 3.5 mm diameter
  • Inner jacket: audio quality soft PVC (black)
  • Shielding: 0.12mm OFC
  • Sheath: RoHS Audio quality soft PVC (dark green), diameter 12.8mm
  • 10A 250V AC
  • Length: approx. 150cm
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorIEC C15
ConnectorSchuko
4 reviews
hum hum..."i can hear the grass grow"...
j'ai un doute par rapport à la prétendue connaissance des personnes rajoutant un signe négatif sous chaque commentaire d'un produit furutech dont la qualité est indéniable, mais bon bref...
This review has been posted for FURUTECH The Astoria E Plus Professional Power câble Pur Copper Alpha 1.5m
Semble TRES prometteur...
Mon cable n'est pas encore rodé mais semble très prometteur. On sent que la scène sonore est bien plus ample et s'extériorise sur un ampli tubes c'est un potentiel de grand et beau son qui s'annonce... une fois de plus merci à Audiophonics pour leur rapidité. Commandé le jeudi soir, envoyé le lendemain à 13h30 si il n'y avait pas eu le week-end je pouvais l'avoir sous 48 heures... Continuez ainsi Messieurs... Cdlt JB
The Astoria :
D'une bonne longueur il sait se mettre en place facilement ;
pour vous laisser redécouvrir vos éléments hifi !
Un câble qui se laisse oublier , je recommande !
Furutech toujours et encore !
Très bon câble , Furutech occupe maintenant toute la partie secteur de mon installation !
Laisse tout passer en se laissant oublier ...
Recommandé !
