FURUTECH The Empire E Professional Power câble Pur Copper Alpha 1.5m
By buying this product you get 150 loyalty points
Reference : 11372
509,00 €tax incl.
424,17 € tax excl.
Shipping date: 25-04-2025.
If you're a musician or recording studio professional, ask yourself this question: Does a Hifi power cord make sense?
The new Furutech Empire E power cords have been designed with the demanding professional in mind. Developed in Tokyo with many talented musicians and recording professionals, Empire E power cords have been specially optimized and balanced to deliver more punch and dynamics to your mixes and studio recordings.
In fact, choosing the right Furutech Empire power cord gives you even more control over the kind of sound you're trying to achieve. Choose the Empire that delivers balanced sound with incredible resolution so you hear every detail and nuance of your system.
Simply replace the existing power cords for your amplifiers, mixing consoles, mic preamps and even your entire recording system, and you'll immediately hear greater sound coherence across the entire bandwidth. Dynamic range will be greater than ever, and music will sound effortless and expansive instead of flat, aggressive or undefined.
Furutech's legendary design team are experts in preserving the audio signal path, delivering a precise, honest and uncompromising end result.
The PC-Triple C (Alpha) power cable used on the Empire-E is the result of an exclusive melting process involving repeated cycles of metal bending, a technique inspired by Katana, the art of Japanese swordsmanship refined over centuries.
This art-like technique uses high-purity, oxygen-free copper. This creates a forging process identical to that of folded steel from the art of the Katana, shaped tens of thousands of times.
This ensures that the joints between the crystal grains inside the copper are rearranged so that the electrical current moves through the signal path more smoothly than ever before.
Add Alpha-treated gold-plated connectors, flexible ROHS PVC jacketing and a patented floating grounding system, and you've got a high-precision tool for extracting the best from music in the studio and on stage.
Features :
  • Equipped with Furutech FI-11M (Gold) or FI-E11 (Gold) and FI-11 (Gold) IEC mains plugs
  • Shielding and conductors treated α (Alpha) for protection against radiated noise
  • Flexible PVC ROHS sheath for improved vibration isolation
  • Field Damper floating ground technology ™ US Patent No .: 6669491 / European Patent (EP1445837)
Cable specifications :
  • Number of Connectors: 45 wires 0.32mm x 3 wires PC Triple C
  • Insulation: Soft PVC audio quality (brown, light blue, green with yellow stripes)
  • Diameter approx. 3.5 mm
  • Inner sheath: audio quality soft PVC (black)
  • Shielding: 0.12mm OFC
  • Nylon braided sheath: RoHS Audio quality soft PVC (dark green), diameter 16mm
  • 10A 250V AC
  • Length: approx. 150cm
Length (m)1.5
ShieldingYes
Section (mm²)N/A
ConnectorSchuko
ConnectorIEC C15
