FURUTECH The Odeon (E) Silver-Plated OFC Copper Power Cable 1.8m
4.0 / 5
By buying this product you get 42 loyalty points
Reference : 12023
219,00 €tax incl.
182,50 € tax excl.
FURUTECH THE ODEON (E)
- Power cable -
The Furutech The Odeon power cable allows your audio or video devices to reach new heights. So you get better sound resolution, greater clarity and wider dynamic even at low volume. In addition, the new IEC connector allows you to connect your cable even to systems where access to the plug is restricted.
On the one hand, the cable is composed of 3 conductors. The first two, made of 37-strand silver-plated OFC copper provide excellent conductivity. The third is also in OFC Copper 37 strands but this time treated Alpha (Anti-Magnetism)
The connectors are also of high quality, composed of copper conductors and also treated Alpha. Nylon / Fiberglass insulation protects the signal from interference in your system and the Polycarbonate body helps protect your cable properly.
Alpha processing includes 2tapes:
  1. Cryogenization of metals by -250 ° C using liquid nitrogen in order to consolidate their molecular structure and significantly improve their conductivity.
  2. Submission of these same metals to a powerful magnetic field created by means of magnets arranged in annals and whose attraction force is constantly controlled in order to leave no residual magnetic at the end of the treatment
TECHNICAL CHARACTERISTICS - CONNECTORS
  • Connector 1:Connector Schuko FI-E11Cu
    • Conductor: Alpha Coated Alloy (Anti-Magnetism)
    • Insulation: Nylon / Fiberglass
    • Housing: Polycarbonate
    • Diameter: 39mm
    • Body Length: 56mm
  • Connector 2: Connector IEC FI-C15 (Cu)
    • Conductor: Pure copper treated Alpha (Anti-Magnetism)
    • Insulation: Nylon / FiberGlass
    • Dimensions: 22 x 30 x 82.2mm
TECHNICAL CHARACTERISTICS - Cable
  • Conductors: Copper OFC plated Silver 37 strands 0.26mm x2 cores / Copper OFC processed Alpha 37 strands x1 core
  • Insulation: Polyethylene 3.5mm diameter
  • Inner load: Cotton
  • Sheath: ROHS compliant - PVC flexible - 10mm diameter
  • Outer sheath: Nylon braided black - 10.8mm diameter
  • Length: 1.8m
Length (m)1.8
Well done
Very good cable for the price especially when connected to a DA converter.
Provides silent and black background for music.
Quite flexible with sturdy connectors. IEC connector could be a little bit tighter but it´s good as it is. Excellent for replacing bulk wires.
This review has been posted for FURUTECH The Odeon (E) Silver-Plated OFC Copper Power Cable 1.8m
