IFI AUDIO NOVA Power Cable OFHC Copper Gold Plated Shielded 1.8m
The iFi Audio Nova power cable offers excellent performance to provide your audio system with a clean and stable electrical signal. Its structure is totally symmetrical. It uses the brand's Ground Zero design, creating a central core that is completely free of magnetic fields.
Reference : 15318
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 24-04-2025.
iFi Audio Nova
iFi Audio Nova Câble secteur Cuivre OFHC plaqué Or blindé 1.8m
The unbraided center ground wire is surrounded by conductors positioned in a double helix, protecting the ground wire from magnetic fields and therefore reducing ground noise. Each conductor is shielded to effectively reject internal and external RFI interference. The double helix design also allows for a constant impedance.
The cable is insulated with polymeric materials, including a high-performance thermoplastic that is moisture resistant and RoHS compliant.
The Nova also incorporates air-filled separator wires, an excellent dielectric that provides perfect separation between the neutral and phase conductor pairs.
Each conductor of the cable is made of high purity OFHC copper for excellent conductivity. The connector contacts are also made of copper with gold plating for optimal transmission. The cable is finally covered with an impact resistant polymeric sheath for increased durability.
Product typePower cable
Length1.8m
Connectors1x Schuko
1x IEC C15
Conductors materialOFHC Copper
Shielding
Operating voltage90V - 265V
Weight595g
Cable diameterØ14mm
Length (m)1.8
ShieldingYes
Section (mm²)N/A
ConnectorSchuko
ConnectorIEC C15
Excellent câble
La qualité de fabrication est impressionnante (attention câble de gros diamètre très lourd). Les résultats sonores auxquelles je ne croyais qu’à moitié en changeant mon câble secteur sont évidents. Excellent rapport qualité prix surtout en considérant les 1,8 m
This review has been posted for IFI AUDIO NOVA Power Cable OFHC Copper Gold Plated Shielded 1.8m
The iFi Audio Nova power cable offers excellent performance to provide your audio system with a clean and stable electrical signal. Its structure...
