LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 2m
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher than 99.997%).
Reference : 15078
189,00 €tax incl.
157,50 € tax excl.
Shipping date: 23-04-2025.
Ludic Aesir
Ludic Aesir Câble d'Alimentation Schuko IEC C15 Cuivre UP-OCC plaqué Or 1m
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher than 99.997%). In addition, the copper undergoes a cryogenic treatment at a temperature of -196°C, which enhances the conductivity of the material. The cable benefits from a high density triple shielding based on cotton and chlorine-free PTFE to reject potential interferences as much as possible. The dielectric surrounding the conductors is injected with nitrogen gas for perfect signal integrity.
The contacts of the connectors are made of a Copper-Nickel alloy and covered with 24k Gold plating for excellent conductivity and durability. The body of the connectors is made of Carbon.
Product typePower cable
Connectors1x Schuko
1x IEC C15
Length2m
Conductors materialUP-OCC Drawn® Copper
ShieldingTriple, high density
DielectricNitrogen Gas Injection Dielectric (Nz)
Contacts plating (connectors)Gold 24k
Cable diameterØ16mm
External sheathPVC
Cover sheathNylon
Length (m)2.0
ShieldingYes
Section (mm²)N/A
ConnectorSchuko
ConnectorIEC C15
2 reviews
Rapport qualité prix exceptionnel
Vous pouvez reprendre le commentaire que j’ai posté pour pour le aesir mais encore plus silencieux et un peu plus « nerveux « . Bande passante impressionnant dans le grave.. J’adooooore
This review has been posted for LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 2m
Très bon niveau en terme de qualité prix
Différence perceptible en utilisant ce câble par rapport au câble d'origine sur une source OPPO 203. Un peu plus de définitions.
Très bonne qualité de fabrication. Très bon rapport qualité prix. Je conseille de le tester.
Ce câble ne détériore pas la qualité du son en privilégiant un registre par rapport à un autre comme certains câbles secteurs peuvent le faire ce qui est un très bon point.
The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity...
